:D i've translet the description for u, its easy our member to understand... B) hehehehhe
As for photograph HPI dry carbon 3 dimensional wing.
2 types of carbon and carbon Kevler are new association! Concept of the HPI carbon wing dry most light weight advanced high-class impression is low price. When the wing is raised, it is light in any case! When the weight of 2kg actualization (there is no foot is) as for prejudice of the high performance making the wing. As for the material quality polyurethane foam of aeronautical technology is included. (C.f. 2) because of that, it became possible to increase the strength of the wing. With other companies it is the wing in regard to one ranking which is not used until now. Concerning safety, inside the wing (the part of the foot) aluminum plate is imbedded. Is the point, (c.f. 1) largest largest feature of this structure part of the foot of the wing and thinking of the safety of the wing itself, the る. Also the blade tip board is to be locked cleanly.
Inside wing
1.) A ルミ board
2.) Q empty technical quality polyurethane foam
Type Size Item turn Price
Dry carbon Kevler 1700mm HPKW3D-17 ¥188,000
Dry carbon Kevler 1600mm HPKW3D-16 ¥188,000
Dry carbon 1700mm HPCW3D-17 ¥128,000
Dry carbon 1600mm HPCW3D-16 ¥128,000
