block is basically the same just with the oil squitters , which doesn't make much difference , the difference is the compression of the pistons , if wanna turbocharge the gti engine , make sure to use the gsr pistons to be on the safe side .
yes, 93T block is stronger. Crank and conrods are also suppose to be different i.e. stronger. 93T also has a small water-oil heat exchanger and the relevant plumbing to make it work in the block... urm, taught we answer this before.
Just notice this morning, at 1st my car water temperature show 85-92C while car is running but when come to idle at traffic light, the water temp start to increase until 100C. Thus I off the Air Con and straight up to fix this problem. Mechanic...
