i using wira 4g93t and wanna help from sifus out there.
during morning,my car can shift the gear smoothly and clutch only need to press half to engage gear.
But when driving in several KM, its started hard to shift the gear ...its going harder while driving in long distance as the engine temperature is increasing but not extreme ...just reach normal temperature.
the problem going worst if i stuck in traffic jam....cannot engage 1st gear , but need to shift to gear 2 (with hard clutch pressing and need to stress the lever to go into 2nd gear) for jump start.
the reverse gear also had a problem when driving in a several distance ,its hard to shift in.
in mid day where outside temperature is extreme, the "kreek" sound is heard in gearbox when shifting to Reverse gear and so on the 1st gear ....(after leaving the parking lot)
the clutch cover and clutch plate i've changed but same problems still happens.
"this problems is occur when my engine is in hot temperature especially traffic jams"
HELP![Bawling :bawling: :bawling:](https://zerotohundred.com/forums/styles/default/xenforo/smilies/bawling.gif)
HELP
