Engine stalling, please help
LoneWolf81
69
Puchong
Dear all,
I'm driving a wira 1.5 manual, when come to nearly stop then engine sometimes will stall once the clutch is pressed. This only happen when the engine is hot. If the vehicle is at idle, simply raise the engine speed above 2.5k rpm then release the accelerator pedal and the engine speed will drop below 500 rpm then it stalled. Air-cond or other accessories does not affect the problem.
I'm suspecting the throttle body is dirty, need to be clean, am I right? How much is the cost to clean throttle body? Or is there any other possible reason? Please let me know, thank you.
Doink
3,492
14
House
ur throttle body needs servicing...that is the problem with idling control...you must say you are driving carb car or injection...
roy27
164
yah.....u gotta tell 1st either u drive EFI car or carbie car......but 4 both operation, u can use the STP carb cleaner n spray at the throttle body n rev it while spraying it....1 bottle spray all 4 better performance...1 bottle is rm13.90......i usually buy in brother's shop
