ELM327 OBD2 Not connecting
nicollim
Jan 5, 2015
9
I recently bought a china OBD2 and try to plug in, and pairing with code 1234 successfully to my samsung gelaxy 4 but when I try to open the Torque apps, it keep saying adapter not found, device not found and also "connecting to OBD via bluetooth fail" keep trying reconnecting but still cant.
Anyway can guide me to connect it? I am driving a honda stream 2.0 (2004).
g88
3,081
54
5,148
first of all is the OBD2 compatible to your car
Waiora_ProTuner
619
221
1,543
i believe its not compatible with your car...
that error msg...everytime..
your phone connected to OBD reader...but that reader cant read you ecu...
I would like to check, how well is the aftermarket brake for 285mm rotor?
Is it about the same as stock?
my concern is, now my WHP is near 200 and i still using stock brake system.
my wheel is using 4 bot instead of 5, 2nd reason is i using 15" rims.
so if i using 285mm rotor type and branded caliper ( in complete set)
will it help for near 200 WHP? ( example evo, wrx, CTR are above 200hp and yet their stock already more then 320mm)
any recommend complete set brake for 15"
