DIY sound proof...
alpha_hoe_
41
Ipoh
hey guys???y spend more??i've an idea but i was no time 2 did it...cost??juz rm20+ onli la....n it's so easy...juz a silicone onli....ex 4 doors juz open the door skin n juz put on it...quite hard 2 explain...wen i done i'll upload pic~!haha~!every where also can even hood......
xavier
65
hmmms... silicone? interesting. ;) hopefully u don't end up making your car heavier than needed. :) Cheers! Looking forward to your 'invention'
donCityZ
2,230
33
1,648
hoe,
complete the diy first, then only post la..
neway, waiting for ur photos too.. its interesting idea.
donCityZ
2,230
33
1,648
whoa.
why u got -1 for iTrader???? i smell something funny here..
donCityZ
2,230
33
1,648
no wonder u got -1 fr stanley la..
i met stanley b4... n i can trust his judgement.
alpha_hoe_
41
Ipoh
i feel the project can work le...but got a bit problem...can soundproof but the heat will increase le...cuz my fren tried liao...DIY fail...kaka...so dun try this at home k?
kelvin---
1,321
Sarawak
... i dun get wut is the point of this thread...1st is say can...then now say got prob...diy fail...-_-|||...i guess the true motive of this thread is to waste bandwidth?
shay
122
miri
Can use the clear silicone. my fren already try. work ok for his car bonnet. no more "metal sound".can hear the bass clearly.
alpha_hoe_, i think u apply it the wrong way.
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
if just some silicone can really sound proof, then y there;s so much research for soundproof material and methods?
btw, maybe silicone can prevent some parts to vibrate...but i dun think tat's called soundproof....it's called proper mounting......
shay
122
miri
thats correct.just to stop the vibration.
burnner
1,563
4
dont put any silicon on metal part of your car body. it will cause karat when and eat your paint away.
civic EH5 (local model)
just noticed my PS fluid are low and found out that my tie rod have leaks. what are possible solution?
p/s: i've replaced whole steering rack less than 2y ago
another question from pic below... do i need to replace bush? (outer tie rod)
