DIY install vacuum valve to bypass stepper motor
boyzone
2,669
38
5,148
Guys,
If I would like to DIY install vacuum valve to control my aircon idling and let my Mitsubishi engine running without stepper motor.
Anyone can help to provide step by step?
I go to this way is because this stepper motor always gave me stalling issue when running with air con.
Pls advice.. Thanks.
4g91ajer
188
U mean that 2 wire thingy...If not mistaken one wire connect to ground and another one to compressor wiring...When turn on aircond then only the valve functioning...
boyzone
2,669
38
5,148
Besides this, there have 2 output from FICD, which is function as input and which is output? Pls advice... Thanks
4g91ajer
188
The top outlet which is adjustable must joint in between air ram pipe and engine head(beside distributor) which u need 't joint' and bottom outlet joint to in between manifold and engine head(near intake manifold) which also need 't joint'....Gud luck
1. anybody can help me here....that day my car broke down near sg besi..the pomen say water pump leaking....i see it my self....but now its ok...no more leaking...can anyone help me what is happening? coz that day the pomen say i have to change the water pump...sumore my fuel and temp meter is kong i think...sumtimes on and sumtimes off....need help here.....
2. why my steering seem to be not responsive? it seem some gap if i turn the steering? can someone help me? sumore i think i have to...
