DIY Honda ECU Repairs- P30 P08 P27
E-Tech
1,115
256
3,183
Johor
yes, but the copper trace is damage, the positive side of the caps what component is it connected. and also the negative side.
at the solder side of the board, i notice that there is no connection, I am i correct?this is for the P08 jdm ecu.
I have repaired a my p27 ecu based on the attached pics you have on this thread, it really helped. the difference it that the P27 ecu have connection on the solder side of the board so i just jumper it.
I dont see it on the P08 ecu so I need to trace it on the component side of the board. the problem is im not 100% where the terminals of the caps leads to. i just have a 80W soldering iron and a pump. no magnifying device.
if you can help me with the schematic where the caps lead to what components I will be able to make the connection. I would really appreciate it. sorry I do not have pics of the board.
all the best!!!
Positive to D5...(the nearest side)
Negative to "ground"...
All (7-8)caps negative is to ground...
Good luck
E-Tech
1,115
256
3,183
Johor
Positive side link to diode on the top side copper.
Bottom side goes no where. (Island copper).
Negative side links to bottom side common ground.
Hope the photo helps....
ryand
47
1,508
Thank you very much for the clear instruction. I will do this on monday and hope it works. need to go somewhere over the weekend.
ryand
47
1,508
hahaha i fixed my po8, i never dreamed it will work fine. no CEL. thank you for the assistance.
however, i have another p27 no burned trace or mark but it would not start.
E-Tech
1,115
256
3,183
Johor
That good! Congrates!!!!
1 cuppa of a good Coffee Bean will do for me....(waiting...)
P27....take good pictures and send me again... let us hv a look.
Fixed many of those......
[email protected]
EH4
21
melaka
A very good info,bro....i can refer ur pic with my ecu P27 to check if got any problem with it...coz my car(eh4 sohc non vtec) sometime the check engine light take a long time(2-3 minute) to light off....some of my friend said maybe my ecu got problem....:(....if i have ecu (P27)problem,can i send to u for repair??...how much its cost??...tq
E-Tech
1,115
256
3,183
Johor
Yes bro... Delay check engine lite off is one of symptom of ecu trouble.
Yes... If cannot diy, yes can couirer to me..
Cost will depend on how bad the ecu condition..
Tq
EH4
21
melaka
ok..thanx bro...one of my civic friend already contact u..but his ecu problem r more critical then mine..(check engine light takes 45 minute to light off..)...if cannot DIY,i will contact u....tq
terenceng
37
long time no see how are u?
u got any friend using K20A-R EK?
Engine swap.. lol..
E-Tech
1,115
256
3,183
Johor
HI Terence....
K engine in EK? Nope...
U planning to do it?
EH4
21
melaka
this morning i 'dah belek2' my ecu n found out,there r 6 capacitor leaking..:(......e-tech,how much for 1 capacitor??..i'm going to try to DIY first..(safe budget..hihihi)...i think 5 small capacitor and 1 big capacitor....(sori newbie,don't know what kind of capacitor)
E-Tech
1,115
256
3,183
Johor
Hi...
caps... rm0.80 to Rm2.00 each...
Good luck on ur diy.
