bucket seat brackets
leynye yamin
leynye yamin
106
22
518
Sabah Sandakan
Hi, i found a pair of Subaru impreza stock semi bucket seats, thinking of fitting them in my kenari. After measuring, the impreza seat original bracket is more less same as kenari bracket. just minor difference. Question is, must i use weiding to even out the difference, or i could just use thick metal plates cut fit to size and use nuts and bolts instead of welding? Thx!! i thinking of Diy install. if using nuts and bolts just fine i could just proceed install myself.
DanzEterna
DanzEterna
15,912
3,371
PJ
www.primeperdanaclub.com
actually u just need to ensure the bolt holes are the same then u could bolt the seats onto the bracket,
if not get the bracket drilled. welding not neccessary.
DLegend
Official Contributor
DLegend
430
14
5,018
Penang
jayjaynyc.blogspot.com
please take care when drilling the bracket, make sure the it will not bend or break easily or else you'll have an ejection seat during an accident.
why not go to a shop and do it?.. they might have ready-made brackets.
