- Jul 1, 2007
- 14
- 0
- 1,501
to all sifu's cani install a turbo tp my 4g92p soch.. please advise me wat should i get if can bolt on.. my engine is using 4g93 pistons
Erm, bigger exhaust? colder spark plugs? custom intercooler pipings? how about stronger internals for higher boost? grippy clutch plate? dyno tune? :hmmmm:change ur piston to gsr 1.get a thicker metal gasket,look for td04 turbo incl
manifold for direct bolt on,get a better fuel pump n fpr,i/cooler,bigger injector
and a piggyback to manage ur fuel n ignition.what else.....:hmmmm:
anyone else wants to add?
if u dun use piggay back basically u cant boost..hw much will cost to buy all the stuff mentioned..can i dont use a piggy back
yea... because oem ecu cant balance the AFR when boost spools up... u need piggyback or standalone ecu to remap the fueling at boost...if u dun use piggay back basically u cant boost..
once u boost the whole engine will die...
i try b4 liao
yups this is so true....yea... because oem ecu cant balance the AFR when boost spools up... u need piggyback or standalone ecu to remap the fueling at boost...
i seen alot of 4G15 BOT but the power outcome will be very limited as well...so better to change to a twin cam engine...hie there..
mine is 4G15, m planning BOT for it b4 i change to a bigger capacity..wht do ya'll recommend me?wht r d thing i need?
4g15 bot can play with stock putra lah... but once ur friends start upgrading their rides, u are left way behind... besides, since u are dumping in 7k-8k for bot turbo kit, why not spend it on a 4g93p (putra or sgti engine) engine... if u have a few Ks more, get a 4g93t gsr, which has even more potential...limited power means????can compete stock putra urh?
juz wanna play around wif mah frens car..
sifu has spoken................4g15 bot can play with stock putra lah... but once ur friends start upgrading their rides, u are left way behind... besides, since u are dumping in 7k-8k for bot turbo kit, why not spend it on a 4g93p (putra or sgti engine) engine... if u have a few Ks more, get a 4g93t gsr, which has even more potential...
but if u are looking into how much u can max out ur 4g15 without worrying on the budget, by all means go ahead...
Who u referring to bro...? Liao..? Hehehee...sifu,
show ur power liao........
of cozs u larr mighty sifu.Who u referring to bro...? Liao..? Hehehee...
Waa....... sulah kena cucuk lor.....
Thread starter | Similar threads | Forum | Replies | Date |
M | Lancer 4B11 Bolt On Turbo Journey with AR60 Custom Turbo | Car Modification | 14 | |
K3-VET/YRV vs Bolt on Turbo | Car Modification | 49 | |
4G13 Carburetor Bolt On Turbo | Car Modification | 71 | |
D | carburator bolt on turbo,izzit possible? | Car Modification | 16 | |
K | Carburator Powerplant with Bolt On Turbo.. Is this possible ? | Car Modification | 7 |
