Hi guys,
Have this stock for sales this month. Please don`t hesitate
to inquiry if interested.
Kaminari Performance
Email add: [email protected]
Stock available at Drift House, USJ.
Thank You
NISMO:
1. BNR34 Floor Mat (Front & Rear set)
2. Z33 Floor Mat ( front 2 pcs)
3. Low Temp Thermostat for RB & SR (SR SOLD OUT)
4. Skyline ECR33 Front Upper Arm USED LH RH Set
5. Big Clutch Operating Cylinder ECR33
6. Big Clutch Operating Cylinder BNR34
7. Long Hub Bolt 60mm Front or Rear (Harden)
BILLION
1. Radiator Hose for ER34 & BNR34 (Upper & Lower hose with clips)
ARC
1. Titanium Radiator Hood Shroud/Panel BNR34 (SOLD OUT)
OEM NISSAN/PITWORK
1. GT-R35 Air Filter Element
2. S13/RPS13 radiator reservoir tank
3. BNR34 N1 Oil Pump
4. BNR34 Pitwork Fan Belts (A/C, P/S & Alt)3 pcs/set
5. BNR34 Rocker Cover Emblem STD
6. BNR34 Rocker Cover emblem VSPEC Nur
7. BNR34 Fuel Filter
8. BNR34 STD Water Pump (applicable for RB25 & RB20 )
9. BNR34 Rear Emblem
10. BNR34 Timing Tensioner
11. BNR34 Timing Idler
12. S15 Aircond Filter
13. S15 Pitwork fan Belts (A/C, P/S & Alt) 3 pcs/set
14. S15 Power Steering Insulator/Rubber & Bracket
15. S15 S14 S13 R32/R33 RB20 RB25 SR20 Pitwork Fuel filter
16. Fairlady Z33 STD Water Pump
17. Fairlady Z33 Pitwork fan Belt (2 pcs/set)
18. GT-R35 Rear Emblem
19. RB25 RB26 Valve Seals
20. RB26 Half Moon Seals
21. SR20 Metal Exhaust Gasket (7 Layers)
22. PITWORK Timing Belts for RB20/25/26
23. VSPEC II Nur Emblem
24. VSPEC II Emblem
25. BNR34 ER34 Pitwork Aircond Filter
HPI
1. RB25 Clear Timing Belt Cover
2. RB26 Clear Timing Belt Cover
Further pictures at:
Pictures by kagekispirit - Photobucket
Thank You for Viewing! :)
Thank You
NISMO:
BILLION
ARC
OEM NISSAN/PITWORK
24. VSPEC II Emblem
HPI
