air filter, plugs n plug cable..
apistate
Sep 16, 2011
23
Penang
need opinion;
which one beter open pod or drop in?
denso iridium or ngk iridium?
beter plug cable?
i :driver: gen2 campro..
sifuu, plz help me..
mADmAN
1,840
547
3,213
open pod with CAI n heatshield
cheapo ngk but change every 10k km
stock cables unless faulty....or if still itchy...can try this
Asiarubber.com - Videos can find the seller in marketplace
apistate
23
Penang
so is it true that if we use open pod, we can get 'long'? n if we use drop in, we can get 'pick up'??
so its beter denso iridium than ngk iridium?
tq..
tq..
Whether you use open pod or drop in doesn't really matter. If your car can adapt to the extra air then good for you. More air = ECU pump in more fuel = more power. Open pod or drop in won't really give you more pickup, that depends on your gear ratios. With the right air filter it'll just let your engine breathe better so less hesitation to accelerate or when you're speeding it won't choke due to lack of air.
Spark plugs are there just to spark and ignite the fuel / oxygen mixture. Whether you use cheap NGK RM30 plugs or Denso Iridiums they work the same. The main difference is the lifespan of the plug. Some smoother acceleration can be felt with iridiums and good plugs but that doesn't translate to faster acceleration or top speed. That is still the same.
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
for example perdana v6...workmanship to change all 6 plugs costs rm180...
so dun hope on using those elcheapo plugs....pv6 has to use good iridium ones that can lasts up to 100k kms.
NAZA Quest (Chevrolet Malaysia) Sdn Bhd announced just established a new business partnership with Indonesian tyre manufacturer; PT Multistrada, to supply the world-renown Achilles tyres to new production models of the Chevrolet Cruze LT Sport. This announcement was made in conjunction with the Achilles Formula Drift Malaysia 2012, where Chevrolet was the official car...
