Bro,200/220 and 250 is the length of the spring.the greater the no,the higher the car will be.
for satria with mivec engine,i recommend f6k 220/50 while the rear is r4k 250/50.
Thanks for the advise.. appreciate.
ur welcome bro.:wavey:Bro,
Bro,im using GAB SS Series for my wira with gsr spring rate. 220. damn satisfy with it. now i feel my car more handling n damn balance.
it's in mm bro vagabond not in inches....i think you mean 220 as the length in inches of the spring ........... not the spring rate, which is usually measured in terms of KG/mm
Bump: i think you mean 220 as the length in inches of the spring ........... not the spring rate, which is usually measured in terms of KG/mm
change to a softer setting for the front bro.I was using 8/4 on my putra , man , it's like bunny hop , whenever road is uneven , can cry , hear all the "thumping" sound , really like gonna fall apart ...
then if u whack corners often , even worst , uneven surface will just make ur car hop ...
brand is subjective.usually adjustable spring rate for gen2 that they selling out side is the samewat will the pro ppl ere recommend for gen2?? wat brand? wat settings? as i really dunno anythin bout modifications (shy to admit :rolleyes:)
why u choose 250 bro?did u set ur car high?i think 220 better.:)Just go to re-set up my coilover.
Finally, able to compensate between handling and comfoft with 5K/250 at front.
that time using HWL , mana boleh suka2 hati say change means change , but now using a brand that can tune until satisfy , problem is , need time to go there and dochange to a softer setting for the front bro.
i buy at trc motorsport. jbBro,
Where did u buy it and how much ?? I'm oso using a wira but it's 1.8.
Tks.
U can try using softer absorber rate, and try deflating the tyre pressure, trial n error.....sees what happens.I was using 8/4 on my putra , man , it's like bunny hop , whenever road is uneven , can cry , hear all the "thumping" sound , really like gonna fall apart ...
