Item : ACL Race Rod & Main Bearing Set for vr4 and 4g67
Info : The unique combination of design, metallurgy and engineering come together to deliver what drivers expect from high performance Trimetal engine bearings.
Features
-Designed to withstand higher RPM conditions.
-High strength overlay plate with reduced thickness for improved fatigue properties.
-Hardened steel backs on all rod bearings to improve the support of the bearing lining and assist with bearing retention in the housing.
-Increased crush for improved bearing retention.
-Elimination of flash plating on the back of the bearings to improve heat transfer through the bearing sand to maximize the grip between the bearings and its housing.
-Increased eccentricity to compensate for bore distortion at high rpm and to assist in the formation of hydrodynamic oil films.
-3/4 grooved Main Bearings to optimize bearing load carrying surface area and oil flow to the conrod bearings.
-Tight consistent wall tolerances to help you maintain consistent clearances.
-Enlarged ID chamfers on bearing edges where required to accommodate large fillet radius on performance crankshafts.
Item Number : 5M1144H + 4B1146H
Features
