- Joined
- Nov 10, 2006
- Messages
- 1,765
- Points
- 1,638
salam
2din carrozzeria pioneer
japan spec
50wattx4
-mp3,wma,wav,mldp etc
-leh baca cd pasar malam/cd burn/cd ori
-tested tiptop (guna sendiri sebelum ni)
-bunyi mmg clear habis,xperlu pakai amp pun dah sedap
-main cd/md
-baru servis tiada masalah
info:
FH-P050MD Specifications
[Amplifier]
●50W?4 ● Maximum output: 50W ? 4
[Ministry Audio
Output Subwoofer: "cut-off frequency> 50/63/80/100/125Hz <slope cut-off>-18dB, -12dB/oct. <Width adjustment> +6 ~-24dB <phase> NOR / REV
high-pass filter (F / R Independent): "cut-off frequency> 50/63/80/100/125Hz <slope cut-off>-12dB, -6dB/oct.
● 9-Band Graphic Equalizer: "Frequency> 50/100/200/400/800/1.6k/3.15k/6.3k/12.5kHz <width adjustment> ? 12dB
●Loudness (volume:-30dB): 10dB (100Hz), 7dB (10kHz)
● Maximum output level Puriauto: 1.8V/1kΩ
[CD player section]
●Frequency Response: 5 ~ 20,000 Hz (? 1dB)
●SN ratio: 94dB (1kHz) (IHF-A network)
● Dynamic range: 92dB
●MP3 Dekodingufomatto: MPEG-1 & 2 AUDIO LAYER-3
●WMA Dekodingufomatto: Ver.7, 7.1,8 & 9
●WAV signal format: Linear-PCM, MS ADPCM
[MD player section]
●Frequency Response: 20 ~ 20,000 Hz (? 1dB)
●SN ratio: 90dB (1kHz) (IHF-A network)
● Dynamic range: 90dB [Tuner]
●FM/AM ● FM / AM
● practical sensitivity: FM/8dBf (0.7μV/75Ω, mono, SN Ratio: 30dB) ? AM/18μV (SN ratio: 20dB)
Of the Common
●Maximum current consumption: 10.0A
●mounting dimensions: 178 (W) ? 100 (H) ? 161 (D) mm
Weight: 1.8Kg
rm350.00 nego
call 012-2270174 mie
shell giant connaught/giant kinrara
info:
carrozzeria | AUDIOF2D MAIN UNIT > FH-P050MD
japan spec
50wattx4
-main cd/md
info:
[Amplifier]
[Ministry Audio
[CD player section]
[MD player section]
●FM/AM ● FM / AM
Of the Common
Weight: 1.8Kg
rm350.00 nego
info:
