Idling After Install Adj Cam Pulley.
JackWaiKit
262
5
www.friendster.com
really depends on wht cams
adjusting pulley sometimes brings out magic
i saw a car jump from 320 to 360 , lol , ask kroolada :P
Bump: really depends on wht cams
it should be installed hi cam condition...
so that can gain more!!!
fct
211
2
3,018
kluang,jb,spore
agreed,even stock cam with adj pully make wonder.
last time friend's 1.8 mivec dyno tune,if set correct can get a 5hp different.
5hp is consider a lot for a na application.
my owned L2s also with adj cam pulley and set different(retard/advance) feel different for the powerband at same rpm reached.
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
The adjustable cam pulley is common use with high-cam, in order to reset the correct idling.
adjusting the cam pulley does not set ur idle rpm...
for twincam yes... as u can set different cam timing for intake n exhaust.... for singlecam engines is different as both intake n exhaust cam timing must be set together...
renxun
1,138
37
1,648
i did a 5 degree retard and it did a very much noticable gain. the engine is more alive and revable. during vehicle test, some even claim they can hear difference in my car's output tone:stupid:
gain how much i dont know. only have butt dyno. as long as it got increment, i let the setting there. did the retard based on reading on google what the australians did with their car that have the same engine as mine
mrevo
86
which side of 5 degrees...exhaust or intake?
renxun
1,138
37
1,648
i cant adjust my intake .. as im only using ultimate piggy back.. altering the intake position will result in my ecu going into limp mode when it detects dislocation on my intake cam position
Quick question... what can affect the length and sustainability of the threads for your tires??? I used to use Falken tires for my 14" rims and they always got worn out after 8+ mths. So, this time around I decided to change my tires to Goodyear Ducaro 4 tires, hoping this'll lessen my need to change new tires every 8 mths. I don't race, I don't squeal my tires often, but I do sometimes take corners a lil bit on the fast side. Do you tink it could be cos my Falken tires were "softer"...
