adding more amp to current coil
grstarbuck
Hi all i was reading here before, but cannot find the topic anymore...
It was about wiring a 12v 30a relay to the existing coil and supplying direct power from the battery... thats all i can remember..... any sifu out there have any idea of this and maybe a post on the diagram will help...
It said to be able to supply a better spark to the plugs for more complete combustion
Thx:regular_smile:
grstarbuck
Thx for the information....i got the general idea now... but need just a little bit more information....
I m using a Bosch 5 points relay and not sure which wire to go which points
30-
85-
86
87-
87a-
this is a 12v 30a one you think it can do the job or do i need to add a fuse on the battery direct to coil connection just in case??
Thx .....:cyclops:
xtorm
1,590
49
grstarbuck
More Power
Thx that site was helpfully! It would be best to see and actual working diagram on a car...anyone try this before? Cause was thinking of cheap ways to up the spark of combustion without doing any major changes to the existing wiring....
thx again
:X-:
Northiswara
2,589
7
this thread dies already. maybe the project fail also.
jin,
u got double plug already still interested with this mer??
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
team99ers.2.forumer.com
jin,
my engine got 12 spark plug.... not 'double' only...:biggrin:
Northiswara
2,589
7
12????
u are using i-dsl lerr. so should have 8 plug. then another extra 4 come from where? from spare plug? or u put another 4 plug at ur exhaust to make the fire dragger...............
JINEIL2EN
Over 10,000 RPM!
15,317
525
Island Of Pearl
12????
mine's V6 la....:smokin:
SOHC V6 Twin Spark...:smokin:
hahahaha...:biggrin:
Northiswara
2,589
7
bro,
u want to tipu me kah?
city where got V6?
to every senior:
i've decide to upgrade my Wira 1.5 SE with ULTRA RACING bars to increase the strength. Anyway, i notice that it has many type of bar, e.g:
front strut bar 4 points
front strut bar 2 points
fender bar 3 points
fender bar 2 points
rear strut bar 3 points
rear strut bar 2 points
rear upper bar
room bar
anti roll bar 16mm
anti roll bar 19mm
anti roll bar 22mm
lower arm 4 points
and i'm planning to install 2 points front strut bar, 3 points fender bar and 2...
