bolt on turbo for my car
shashitharan
14
to all sifu's cani install a turbo tp my 4g92p soch.. please advise me wat should i get if can bolt on.. my engine is using 4g93 pistons
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
change ur piston to gsr 1.get a thicker metal gasket,look for td04 turbo incl
manifold for direct bolt on,get a better fuel pump n fpr,i/cooler,bigger injector
and a piggyback to manage ur fuel n ignition.what else.....:hmmmm:
anyone else wants to add?
ken12292703
Drives a shopping cart...
1,542
5,138
SoMeWhErE
Erm, bigger exhaust? colder spark plugs? custom intercooler pipings? how about stronger internals for higher boost? grippy clutch plate? dyno tune? :hmmmm:
karl5511
1,014
Block? No need to change? Or 4G92 block already got oil squirter.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
imo,it's not necessary if ur boosting below 0.8bar.there's a few 1.6 bot
running around w/o it.if got,better la.:)
BananaBoyz
217
we got full metal gasket for 12v 4g13/15 rm240 1.0mm....semi metal mmc 2.0mm rm175....name it what you want...intercoler,injector or custom banana...we dont this project
shashitharan
14
hw much will cost to buy all the stuff mentioned..can i dont use a piggy back
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
there's 1 runing w/o piggy.other's i'm not sure.ur engine is running on maf so
it's much more easier to bot.
sanygsr
181
Hi there..
Better u find completed gsr 1.8 turbo head + turbo + gsr intercoler + turbo host and metal gasket . Now cos around 3 k if u lucky...last time coz around 1.5 k. Then add external fuel pump + e-manage.
done.....
Or 2nd option, find gsr injector, gsr turbo completed with maniful , metal gasket, turbo host, intercoler, external fuel pump , e-manage.
done
Then 1st optionu will get twin cam turbo and 2nd option u will get single cam turbo.
main thing is money.........
gud luck bro
korupted
158
hie there..
mine is 4G15, m planning BOT for it b4 i change to a bigger capacity..wht do ya'll recommend me?wht r d thing i need?
My Honda City 2006 making some engine knock noise like Proton Wira & Iswara when slow driving. Is there any one know what is the possible cause and where can get the specialist to solve this problem in Ipoh? Thanks.:confused:
