Unstable Peformance
hillies
46
Sometimes the car is very light and u can feel tht it's akinda powerful.. But sometimes it's heavy and sluggish.. What is the problem? THe peformance is akinda unstable I would say.. At times it's very powerful at times it's very sluggish... 4G13 engine only :(... BEsides, is there any tuning to be done? heard from a friend who told me about tuning the carb and exhaust can cause a misfire during gear shifts? is tht true? if yes, how do we exactly tune it?...
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
maybe ur a/c kick in,u feel sluggish le.about tuning carb,this u have to wait for
sifu skywalker.he's good in proton 1.3/1.5 carb.:).he can tunjuk ajar u.:).
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
me pulak??... ish...
no power coz aircond compressor kick in mah... blardy main culprit is the compressor... sucks away almost 50% of the power...
why u wanna tune ur exhaust to misfire??.. misfiring is a bad thing la.. aiyo...
u want better pickup or top speed??... done any mods already??... try advance ur ignition timing a little for better throttle response and pickup... top speed will suffer la... max u can go is about 140kmh only....
as for carburetor tuning, jz go to any workshop and ask them tune lo... 10bucks to tune the carb AFR and other stuff...
or u looking into more performance??... as in highcams, performance carburetor, port polish, bla bla bla??... budget??...
hillies
46
Ooo haha.. Thx 2 all d sifus.. well I've ald done the high cam thing.. but for now still ok ler... I've tried, nt a very long highway though, maybe 5km +/-almost reaching 160km/h, using 1.3 carb... is it ok? How come misfiring is a bad thing? looks very 'yeng' with a bit of fire at the tip of the exhaust hahahxx.. :)
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
ooo... fully modded adi... fuhyoo...
what cam duration u use??... if above 272degree, usually u will suffer abit at low end... using adj campulley as well??... if still sluggish (even with aircond off), try get a proper mech with know-how tuning on highcams and so on... highcams, valve/tappet adjustment, campulley and carburetor all need to be configured to work with each other well to get the best out of ur highcams...
misfiring happens when spark occur when ur exhaust valve starts to open... this usually occur when ignition timing is not correct couple with high duration camshaft...
but in some cases such as turbo cars, misfiring is purposely induced to reduce turbolag during deceleration... when air/fuel ignited during the opening of the exhuast valve, the detonation will push the turbine to spin fast even under deceleration... yes, this will damage the turbine in long term... but track cars with time attack in mind wouldnt care much about reliability... all they want is fast lap time...
boyzone
2,669
5,148
go for 13 or 14 inch light weight rim, might help u to improve ur pick up.
Btw, is it worth spand some $$$ go for 4g91 / 92...
economy and reliable instead of spand a lot into 4G13.
tofu_manic
1,342
91
5,148
sifoo sky has spoken! :adore:
if not mistaken the aircon sucks away more than 10 HP according to one guy who dynoed his 4g15... :sheep:hehe
seanlee
382
3,018
if you have done high cam..also so on...
bring your ca to DYNO...so that you can se the graph weither it tune the proper way also the misture of A/F is it correct..
this is the proper way to know your car tuning...
also like sky said Mis firing..is not a good thing to do...YEs is look Yeng and Cool....but hell if you afford to get another new engine in short time...then be with it..
if Missfiring look cool and will not harm the engine...i think alot people in straight ou looking at already have liao..before you know...
DDOLINK
209
wahhh sky..now become sifu edi arr..btw, no need to on aircond la when u want to speeding..try to tune ur carb..tune using the CO2 machine and find a reliable mech..i have tune my carb after doing my exhaust setup now the performance and fc is better..balance is what i meant
hillies
46
Ooo.. well.. my car where got fully moded ler lolx.. just minor mode oni ler sifu... exhaust all oso din change yet.. just change centre bullet oni lol... all stock hahaxx....
guy's,
how many of you here willing to spent for oversize with sleeves kit? Also to risk it? I happen to have extra engine kosong lying around and having a thought to "build" it. Im looking to oversize it from 79mm to 82mm with darton sleeves kit.
but i've reading that sleeves wasnt easy to install. It required very skillfull mech to do it. Else risk sleeves moves or so on. This question me is it wise to do so? Im going sleeves as i want total reliability. Not to mention gasket
thn...
