minibeany
598
102
543
These are the old arm took out from the car. I found out that the ream lower arm is juz U shape compare the 1 I bought it had a extra plate cover it.
going to change mine too after seeing these pictures.
- full set front and rear lower arm
- absorber and spring
- front anti-sway bar from 1.6/1.8
minibeany
598
102
543
some small maintenance work...
swapped front & rear lower arms, all the links with new bush
upgrade front & rear 1.6/SE absorber and fitted with Ftuned spring.
front and rear anti roll bar.
flush radiator and filled in with coolant
change soften brake hose to steel braided hose
in the midst of swapping, found out the drive shaft not align... realign back.
no more bunyi tikus and like a new ride... hehehe...
Reactions: sweelt and vr2turbo
sweelt
Nov 6, 2016
2,306
248
next round put superpro bushes ...lol
Reactions: minibeany
KHNG940413
668
56
johor bahru
yes, no more sound... i fitted a Ftuned spring... nicer handling.
also, braided hose for all 4 disc brakes.
BTW, how are you? didn't hear from you for quite a while
I am fine Thx. But sadly my wira is wreck. Hit by a car on the back. The car is total lost and I walk out from the accident with just some minor wound only( hand & head)
  • Wow
Reactions: sweelt and Izso
KHNG940413
668
56
johor bahru
Ftuned spring, I had also install to my jazz. Mated with Kyb RS ultra. The result is nice for me. Stable on high speed and also better then stock in corner.
ok .. here goes.... im having difficulties on my next project here... i have an E-Class 1995 Mercedes. I have researched and asked many people stating that i need to place in a Toyota Supra or Celica engine... what do you guys thinks... how much will that cost? will that effect any of the handling? will it make it even better or worsen...my budjet is aroung 60k.. please help me here...cheers
