16 or 19mm for Honda City gm6
ben18181
Jul 8, 2020
9
24
Hi guys. I have a Honda City gm6 2014 v spec. Want to know 16mm or 19mm Ultra racing anti roll bar works better for my car as i feel the car floating during highway drive. My car is all stock and tyre is cc6. I am not a fast driver and I just want my car to be stable when I am on highway.
leinnz
333
57
3,028
wider tyres for 1st try?
marsha1l_v6
666
130
543
try change new tyre first.
i had same issue as yours with my city, change to cpc2 195/50...better at highspeed cruise..
nw111
81
34
Terra dei Motori
Upgrade tyres first.
leinnz
333
57
3,028
sifu semua advice cheap mod or remain stock. why ah?
The purpose of the ARB is to prevent or lesson body roll in corners. If you are driving on a straight highway, the floaty feeling is caused by tyres, wheels, suspension only. Adding a thicker ARB isn't going to do much other than emphasize on bumps on the road.
It's like all the big-guns here have said - start with the most obvious and potentially the cheapest (in the long run) choice - change your tyre size. If you have the budget go change to lighter and maybe slightly larger rims. If I'm not mistaken the GM6 comes with 16" rims - so that's plenty big already. Maybe you can go 205/45/16 tyre size.
If after that it's still floaty - then look at your suspension/spring setup.
Reactions: leinnz
ben18181
9
24
Can city 16inch rim go 205? Because best for 6jj is 195 right
leinnz
333
57
3,028
I succesfully installed a new headunit . However now the central locking and alarm aint working. Ive checked all the fuse and all in working condition. Anyone can shed some lights into this ?
