Hello anyone got any experience fitting a open air filter to the 2009 proton satria neo
Sent from my SM-G935F using Tapatalk
Yes, but drawing in cool air, right?i still using stock airbox filter....looking how the inlet pipe turn right/left/u turn/up turn....only see the mouth. lol....
Hi all thankyou for the replies, I have found these to products on the interest made for the satria neo, either proformance air box with stock intake or stock air box with the proformance air filter intake, any views on these?
The second photo doesn't look like a stock airbox, isn't it? Or is it just the intake scoop is replaced by the carbon scoop? If it's like that, then I think both are just useless! I think the first photo is just to make suction intake noise hence got that tube in the middle of the intake pipe, while the second photo if just the scoop then just for show only! Maybe the scoop is a bit bigger than stock then theoretically should help get more air but in practice I doubt it'll make any noticeable difference. You better off just to replace the air filter with a drop-in after market replacement like Works.Performance air box with stock intake meaning stock filter? then is stock only. Better off with stock box with performance filters....
yes drawing cool air.Yes, but drawing in cool air, right?
Theory suck more air but block by stock filter......lolThe second photo doesn't look like a stock airbox, isn't it? Or is it just the intake scoop is replaced by the carbon scoop? If it's like that, then I think both are just useless! I think the first photo is just to make suction intake noise hence got that tube in the middle of the intake pipe, while the second photo if just the scoop then just for show only! Maybe the scoop is a bit bigger than stock then theoretically should help get more air but in practice I doubt it'll make any noticeable difference. You better off just to replace the air filter with a drop-in after market replacement like Works.
