Adjustable
hi all..
i use adjustable but too soft..
how to setup to more harder..
:hmmmm::banghead:
Full Adjustable? Firstly try compress the springs and tune damping to harder. If that fails, change to harder springs...:driver:
sweelt
Nov 6, 2016
2,306
248
Got body shift, dun need set spring preload / compress spring.
Can use to lowered the car.
From your pictures, got two lock. No body shift. :hmmmm:
Yah! picture show HLSH only. Compress spring the car will go higher. No damping adjustment too.....
Had been confusing about this product which called voltage stabilizer.
Most of the seller claim that after installed with a voltage stabilizer will have following benefits :
Brighter headlamp
Better fuel consume
Smoother gear change (auto)
Torque and HP increase
Longer battery life
Cooler air con???
And so on, some say it needs to be works better with grounding cable. Some say only higher model will give benefits like Hot Izanma, Qmax. And another information from a shop which...
