Car couldn't Start Eventhough the Battery Was Fine
CLS78
113
46
Yesterday evening i encountered a problem that i've never encounter before...My Suzuki SX4 suddenly couldn't start....I've double checked the battery was fine....Lights can be lighted up....radio can be on.....air-conditioner can also be on...in fact everything was fine and nothing was wrong.....The petrol was half the tank...However, after cranking a number of times....the engine just wouldn't start....I had to towed the car to the workshop from home....The mechanic told me that the fuel didn't reached the engine to allow the spark plugs to spark the fuel for the engine to start....This has never happened before....
Does anyone knows what the problems might be?....Is this normal or a rare designated engine problems?....Do you think the mechanic was right about what his diagnosed was?.....Your opinion is much appreciated....Thanks :adore: :adore: :adore:
Since already at the mechanic, he did not settle the issue? Looks like fuel pump or check the fuse first....
CLS78
113
46
he behaved as if he knew nothing and not knowing how to fix it....I'm kinda uneasy with this mechanic....do you have any good mechanics that you can recommend?....preferably Selangor or KL area....thanks
Can be fuel pump or fuel pressure sensor problem. So even if the fuel pump still fine but if the pressure sensor already spoiled then that prevented the engine to start coz it tries to protect the engine.
sure fuel didnt reach?
or was it crank sensor?
Pm you the contact dy.....:driver:
CLS78
113
46
Its fuel didn't reach....got cranks...just would ignite to start the engine
Sent from my SM-N9005 using Tapatalk
CLS78
113
46
I've never encounter this problem with my other car before....this was the first...is it a normal with suzuki only or other cars can be infected too?
CLS78
113
46
Can try to send back to Suzuki service centre?
I was adviced not to send to suzuki service centre cos was told that their workmanship aren't that good....so searching for outside mechanics who expert with suzuki
sweelt
Nov 6, 2016
2,306
248
Did u face any symptoms of need to crank longer than usual. Before this current issue occured.
Might be feul pump or weak battery.
an Affair with the wild horse
It has been quite some time since we had time to update our post
when my buddy asked us to guve a good good bath to his horse
Upon seeing the ride
came with much dirt
need a good good bath...
