Exhaust setup
GuyInPersona
63
Hey guys I know there are couple of forums on this but I just wanna make things clear....
For now my car is std engine wise and mainly upgrading on handling but wanna get into performance next. So what would be the ideal exhaust setup for campro ? I just want power more to mid and high only and don't really care on low. Is 421 header with 2" pipe all the way back and straight flow muffler setup will be ok for Campro Manual ?
KenDiriwan
1,283
225
kendiriwan.multiply.com
Std engine huh, i suppose 421 should be ideal for your demand. 4-1 shines for utter high rev prepped engine(aftermarket internal ofc) but you'll sacrifice both low and mid range. What displacement is your engine? You would want to consider a higher flow cat-con as well.
GuyInPersona
63
1600cc campro persona.....currently std engine with aftermarket open pod only but planning to do more mods in future. Aim is mainly for pickup... Top around 180-200kmh enough.....current setup 421 with spiral bullet and straight flow muffler with std piping but wasn't really satisfy.... Hehehehe
lsm1991
1,469
185
top speed is honestly useless! its how you get to that top speed that counts!
You said you don't care about low rpm but then wants pick up, that's a bit contradictory. For good pick up would need good low-mid range response.
GuyInPersona
63
i dont really know how to explain this but the pickup i mean is during rolling...lets say in gear 2 at rpm4 then to push to rpm6.5 so in that term....not really the pickup from moving from 0kmh.....not really sure the term...still new to this car world
29,998
Got it, you want mid to high end acceleration......:driver: but town driving will suffer woh! and being manual got to switch gear often....:banghead:
Seriously - modifying this car to get mid-high torque will be a challenge. An exhaust isn't going to help since this car was designed for the highend rev range. You're better off changing your expectations. Or just drive hard and fast in the top rev range all the time.
I have a problem with my manual gearbox on JB-JL L512. I am now unable to push gear into 1 or 2. I can push the gear shifter to the left and to the right. But, I can't push from the left side into either gear 1 or 2.
Previously, it worked fine until last month where the symptom started with the difficulty to change gear to 1 and 2 (I mean, I managed to put into gear 1 or 2, but with a struggle).
But, I have no problem to push to 3,4,5 and reverse gear, yet.
DO you all think the problem...
