Multi Function Jump Starter
Hi guys,
Lately having problem with my car battery. The battery having parasitic drain. Send to wire man also cannot locate the drain. Off alarm, take out HU etc. still draining. If don't drive for 3 days the battery will be drained until cannot crank the car. If use daily then it is okay.
My car is manual and have jumper cables, means can push start or jump start but then when alone both also useless.
Then made research and finally ordered a Multi Function Jump Starter. Sort of a Power bank but capable of cranking up a car. Was delivered yesterday, charged it up and made a trial today.
Remove the +ve positive terminal from car battery, therefore no more power coming from the battery. Clamp on the wires to +ve and -ve terminal, plug into the power bank, alarm went off, means voltage pretty strong. Turn on the key, instrument panel lights up. Crank and car started. Shut down and tried again and started.
Initially was quite skeptical that the power bank have enough juice to crank the car. So having tried it myself, therefore just sharing this with you.
Here are some pictures.....
Comes in a nice bag
Power bank comes with jump cable, laptop cable, phone cable, AC charger, Car DC charger etc.
Hook up for trial start
Instrument panels lights up, and alarm went off....
Supra_Fanatics
20,673
3,998
How much u got it?
Bank rechargeable ?
Yup, just like our hand phone power bank. Rechargeable and have output for 5v (hand phone), 12v (automotive), 19v (lap top), and 12v for cranking up the car
---------- Post added at 04:11 PM ---------- 6 hour anti-bump limit - Previous post was at 04:10 PM ----------
Never say. I was selling ma.
Never saw it in your shop mah!, but anyway just only I needed it, just in case. All the while rely on my jumper cable......:biggrin:
---------- Post added at 04:13 PM ---------- 6 hour anti-bump limit - Previous post was at 04:11 PM ----------
How much u got it?
I search and most selling RM200 plus, got RM199 also for 12,000 to 14,000mah. This one got from groupon 15,000mah for RM168.....:biggrin:
ken yeang
6,617
1,327
vr2turbo,that is some very "juicy" jumper.
I wonder it can be used to sot-sot people....:biggrin:
ha! ha! sot sot people need much higher voltage.......:biggrin:
There is a LED bulb at the side that can be switch on as a torch light, fast blinking light and slow blinking light.....:driver:
ken yeang
6,617
1,327
that is indeed a very handy piece of gadget....
Any idea what is the batt cycle count?
Supra_Fanatics
20,673
3,998
Cheapest way, if car breakdown and cannot start. Call Vr2turbo bring his charger :rofl:
Hey there , i got a Wira 1.5 just converted to manual transmission using F5M21 gearbox with clutch pump , im using Castrol MTF 80w90 GL-4 gearoil with it as far as i know from research this gearbox can't use GL-5 oil which will corrode & cause damage to the bronze syncromesh inside .
The issue I'm having is sometimes when shifting into 2nd gear kinda hard , can feel like 2 step movement when shifting & when shift into 3rd gear sometime can hear & feel a little bit of grinding but it will...
