Ultra Racing Product??
about proton crack firewall u know la the firewall very2 thin...even if using racing clutch (hard to press clutch paddle) also results on cracking the firewall :biggrin:
another famous area for cracking was at the fender chassis (between the strut housing and firewall)..this problem i use UR fender bar to reduce further damage.. :adore:
*in this picture u can see clearly on crack at exactly above the UR fender bar
*another spot of normal crack for this kind of car was near the bonnet rubber lining (top left in picture)
this shows that area have been flexing from the day it rolls out of factory..metal fatigue (worse if use adjustable suspension with harder spring rate) :adore:
beatnik
924
74
3,028
What I meant was to allow a certain flexibility instead of completely rigid...
This.
also note that adding all possible bars at every corner of the car is not a substitute to a roll cage.
roll cage's primary purpose is to protect the occupant during roll-over (turn turtle). chassis strengthening is just an additional benefit.
speed2horizon
2,798
334
1,683
This.
Yeah... that's what I was trying to say... No substitution for rollcage...
lancemapei
105
11
thanks all bros comments,
any others way to get perdana chassis enhancement product like Cusco?
or custom make aluminium lower bar?
nasr
70
3,008
Just install fender bar to my ae101 and the result as what pomen GTR said -
more stable handling especially at bouncy corner road..a good investment..
speed2horizon
2,798
334
1,683
Yeah... Good steering response too..
there's also another chassis improvement method yet to try..
autofoaming....
well maybe later in the end year would do the track package for side sill foaming.... :smokin:
speed2horizon
2,798
334
1,683
autofoaming....
Pro and cons.
Pro, Noise Sound and Vibration reduction.
Felt the Car as 1 piece.
Cons.
If any slight accident th causes dents on any of the ABC pillar, Rocker Panel. Then, the makatlou will be coursing ur next generation... Lolx...
D7zul
2,697
848
Shah Alam
Cons.
if there's no foaming also got problem, right? :biggrin:
speed2horizon
2,798
334
1,683
Hahaha.... The problem is not about the rigidity... The problem comes when u repair. If u filled up all the sections, how the tool gonna reach the outer panel leh.... I'm not siding anyone/brand/product. In fact, I'm complimenting it for the SNV insulation and rigidity...
This is purely based on my friends n my own experience with the foam. One of my friend is also makatlou(ketuk body). He was cursing the owner when the car was sent for repair... Hahaha....
surely it is... :biggrin:
Haha... looks like some experience there...?
Hehe:smokin:
not my car boss.... :biggrin: but still tempting to try it...just will not do all package la....just some key area maybe...
even if we think about it if the foam already filling all the hollow panel on the side of the car surely bodyshop foreman scratch head how to ketuk back when the panel dented.... :hmmmm:
no wonder your makatlou fren tiau the other guy kao kao.... :banghead:
Pomen : If you go autofoam let me know. I've been wanting to do for a while, but never had the time or money. DIY for this is highly tempting but after surveying the prices of some of the better products out there, it's almost the same in price.
actually i've been eyeing for long to DIY the foaming mods....but after looking highs and lows about so many range of "possible" foam and the long process to get it right 1st time, i decided to let the master to do it...autofoam to be exact....will be doing full side(door) sill foaming with high density race formula foam(i think it would be the hardest and heaviest of foam)...recieved quotation from desmond for my car....slightly higher than i tought it would be...hence explain the long wait.... :smokin:
