modding brembo, sifu pls help!
sitnalm
65
Is the Evo 4 master cylinder able to supply sufficient fluid for brembo 4 pot ? though i am not sure if evo 5 brembo piston size is same as evo 6/7/8/9 brembo but the master pump size is 17/16" whereas Evo4 is 1".
Peterj and all, grateful if you could share your experience. Thanks a lot
peterj
1,321
258
1,683
Kuching
it is sufficient
sitnalm
65
the lock up at rear wheel ? is that due to brake bias ? Thanks
Peterj, sorry to highjack your thread
peterj
1,321
258
1,683
Kuching
i am using it now and i din feel i need push so much to feel the brake,just step on it like normal brake..... if i not wrong, there i no much different on evo 4-6 servo.... and my brake din lock up till now, even i do hard emergency braking on 120km/h.... without ABS
sitnalm
65
Thanks Peterj,
Is there any difference on evo 3 and 4 servo, i mean are they interchangable ? If i recall correctly evo 3 servo was 1 inch as well.
peterj
1,321
258
1,683
Kuching
how u measured it is 1 inch? u mean the thickness of the servo(black parts) is only 1 inch?? evo's servo are double layer, at least 10 cm thick if i measured the thickness of the black parts.......which is 4 inches ..... for me, no much different.... the 1 inch servo are oem proton or lancer maybe
evo 3 servo
http://www.zerotohundred.com/newfor...mance/275807-brake-servo-evo-3-with-pump.html
waja servo
http://www.zerotohundred.com/newfor...-waja-servo-n-master-pump-for-sale-rm130.html
see my evo 4 servo, but not detail
Log masuk | Facebook
sitnalm
65
i was referring to the pump which is 1 inch. you should be able to see the '1' mark on the pump. some pump is 15/16" size. For evo 3, i suppose it is 1".
i could not see you evo 4 master cylinder from facebook, can u correct the link ?
jawsbite
Apr 5, 2011
36
2
508
The 1 inch is the ID of the master cylinder, not thickness of the servo.. All early Evo is 1 inch, those with brembos comes with 17/16 inch.. As stated its casted with the marking on its side. Pedal travel will be shorter with bigger size master cylinder, but less leverage (more effort need to be applied vs the smaller ID to achieve the same force).
xcheong
1,650
so how is this mod coming?
can the rear successfully mod into an E3 trailing arm?
and front brembo can bolt straight to evo 4 knuckle?
My ride proton saga blm hav juz been banged into a pajero. However, the pajero totally no damage as it has spare tayar protected its, but my saga blm bonnet damage and concave and the front bumper slightly drop. So far the other side's car no injured, I tend not to claim insurance as my ncd already up to 55%. It will be saver in long run.
The problem now is where should i go to repair my car is the best choice? proton service branch? proton authorise service? or juz normal workshop? My...
