Wira Aero Titaned !!!
gasing
gasing
7
Yo !!!! :D
Titaned my car on 19th Oct with the height adjustable kit (hi-lo). It seriously redefine my car handling. The handling now is like TOTAL diferrent. Superb !!!! :rolleyes: So far have done 750Km on it, have to wait till everything inside the shocks settle around 1000Km
Previously i have lowered my car with the common solution, lowered spring that matches with APM R-tech... Monroe Reflex... etc... etc... for improving the handling and stability. I beleive that there's many people still running around with this solution. But after changing to TITAN nothing match Titan comfort and cornering ability as the improvement is VERY VERY significant la!!!!!! :o
Now i regret that why i'm so stupid for not commiting to TITAN very much earlier la.... :angry:
It's really hard to explain the WONDERS that happen to my stupid Wira... So pls try it out.... Sure that you will fall in love with it. <_<
This is just a form of sharing for all the others that haven't decide or don't beleive what Titan can provide. :D
gasing
gasing
7
Yo Ninja fella...
hey.. now i'm aiming for pillowball liao la. How long can it last?? As like what i told u that i use my car excessively.... sales man mah... How ah..?? :D
By the way where is my picture ah.... ?? <_<
gasing
gasing
7
Ha Ha !!! :lol:
Just fitted PillowBall Mount on 24th Nov...... Superb !!!!! :D
It really work like what .... speedking said:
Attacking corner at slow speed = er..no different wan?
Attacking corner at fast speed = Woo...feels like ur car is begging you to go faster ...in short, less understeer...
You wont feel much different when u are "going in" to the corner...u can only feel it "in the middle" and "going out"....especially those long and sharp corners...
After finish testing the car...my heart beat still at normal rate..OK...tomorrow can go faster
Also have the front shocks harden as well.
Very impressive handling... B)
Hope this is informative to everyone. Seriously worth every single cent spend. :)
slk850
slk850
886
Penang
Another satisfy customer. Welcome ! :lol:
MRV
MRV
25
gasing, im using wira too,
may i know how much did it cust u to fit your wira
with titan's bro? ;)
MRV
MRV
25
gasing
gasing
7
Yo MRV...
The suspension was RM 2800 like what ninja said. The Pillowball Mount cost u better ask ninja as well. :P
It's time to change to Titan, 100% solution for what you want since its customise to your very own need. B)
mattbok
mattbok
7
Ninja, I'm presently using Monro Reflex for all 4 with stock spring on my Wira 1.5 last year. I've also installed rear arb recently. While I am satisfied with the handling especially in attacking corner, but the comfort level is low on uneven roads.
I'm considering the Comfort type, partly due to the fact that I would settle for comfort than handling and also partly due to budget concern.... kekekeke. My concern, will the handling remain the same with my present Monroe's or better?
If I were to install them before transplanting MIVEC into my car next year, will the suspension be compatible with the upgrade then? This is raised as usually, the suspensions for 1.6 & above are different compared to 1.5
Do I have to make appointment for the installation?
Thank you. ;)
ninja_iga
ninja_iga
3,376
Thank you. ;)
hi Matt
wow
Well.. this is abit interesting
if you want better comfort with control, YES you can use back your stock springs and our dampers :)
it'll be the cheapest alternative :)
but if you plan on converting, to anything bigger, heavier, faster than what you have now, PLEASE go only for coilovers.
your stock setup WILL not cope.
but if you're staying stock engined all your life, no problems then :)
it'll make all the difference in the world.
yes pls PM or Call me for an appointment
mattbok
mattbok
7
Ninja, thanks for the fast reply :)
from your explanation, i believe i should go for coilovers even now since i've decided to transplant the engine in the future. Am I correct?
Can I know how much would it be in this case?
Thank you.
ninja_iga
ninja_iga
3,376
Thank you.
yes that's best IF you're gonna convert la
it's still RM2800 :)
chelnick
chelnick
242
Thank you.
do get coilovers...
i did my titans when my car was still 1.3...
now i'm using mivec.... just sent the titans back for a retune ..... and its working perfectly again ;)
btw after the transplant the old suspension setup(titan before retune) was actually still good for the car... but i'm fussy so had to go stiffen the ride.... :lol:
gasing
gasing
7
Originally posted by chelnick+Dec 15 2004, 23:27 --></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (chelnick @ Dec 15 2004, 23:27 )</td></tr><tr><td id='QUOTE'><!--QuoteBegin-mattbok@Dec 10 2004, 11:34
Thank you.
do get coilovers...
btw after the transplant the old suspension setup(titan before retune) was actually still good for the car... but i'm fussy so had to go stiffen the ride.... :lol:[/b][/quote]
hmm.. nice engine la.. Just nice for you 1.3 upgrade.
I'm currently driving 4G91, What's your setup for suspension?? Mine is retune to sligthly hard from medium and the back is still medium....
