wira 4g15 can use standard piston perdana v6?
squintex
squintex
13
hi guys,
i got this wira 1.5 injection owner asked me if he can rebore his current block and change to perdana v6 piston. i already googled for piston v6 size but didnt return any result. so is there anyone know what size is piston perdana v6 and can it fit wira 4g15 block after rebore? i only know that current wira 1.5 piston size is 75.5mm.
thanks
DanzEterna
DanzEterna
15,914
3,371
PJ
www.primeperdanaclub.com
perdana v6 piston is 78.4mm, recommended rebore an extra 2mm of your original diameter. so means the max u can rebore is 77.5mm
how bout 4g93p pistons? u know the diameter?
---------- Post added at 07:58 AM ---------- 6 hour anti-bump limit - Previous post was at 07:54 AM ----------
bro, hope this helps .
Engine Cylinder Head - Autoworld Forum
budakkampungaje
budakkampungaje
317
38
Dengkil
6a10 1.6 V6
Bore, mm 73
Stroke, mm 63.6
V6 piston..
Bore, mm 78.4
Stroke, mm 69
1.8 4g93....
Bore, mm 81
Stroke, mm 89
6a11 v6 1.8 soch....
Bore, mm 75
Stroke, mm 69
squintex
squintex
13
thx for the info, i know 4g93 cant fit wira 1.5. the diameter too big from original diameter. this is too unfortunate. i already booked the perdana v6 piston because a friend of mine already fitted v6 piston into his wira 1.5. that mean he rebored almost 3mm from the original size. :(
peterj
peterj
1,321
258
1,683
Kuching
careful:adore: hope u are not the next person that crack the engine block like my previous fren done:biggrin:
peterj
peterj
1,321
258
1,683
Kuching
rebored 3mm, cracked when play wif ppl, at first smoke come out, check compression lost, open c a crack , then just throw and transplant a 4g91... lolx.... ppl wan re-bore 2mm already wanna die lor, and it is still within the safety limits, over 2mm, no ppl dare to say sure safe especially the block itself is unreliable and thin, unless u rebored and drive rpm < 3k then it will be safe than..... pls, dun do anything harmful to ur car's heart, u broke it's heart, it will broke ur wallet...... XD, dun watch too much initial D too, rev and maintain in redline for long period of time is not easy like in the movie
squintex
squintex
13
dang! i guess i just have to cancel the booking and tell my friend about this. i dont want to test something on other ppl car then later they come back blame me lol.
peterj
peterj
1,321
258
1,683
Kuching
i just give opinion only bro, u can try to do and prove it is good and reliable or not, then i will but another 4g15 and do it:biggrin: :biggrin: maybe u got luck le:biggrin:
squintex
squintex
13
maybe i should just ask this. other than 1.6 stroker kit, what other piston is usable for 4g15 let say size 76mm or below 77.5mm? small budget so couldnt go for 1.6 stroker kit. looking for high comp piston because afaik std 4g15 piston is not low or high comp. flat surface one.
peterj
peterj
1,321
258
1,683
Kuching
save the money 1st, many things cant do alang alang, for me, i would take advise from sifu i have been heard at zth, use misubishi magma low cp piston + metal gasket + emanage + tdo4hl or subaru's ball bearing tdo4, it will pump out more power than change piston, if wan remain na and improve some power, suggest going for pipercamshaft, or other high cam with adjustable cam pulley, port polish, k&n , open pod, engine management, hotbits exhaust mod, piston and those rebore stuff should do the at last since it is not simple stuff, i long time din play na already so cant give more good suggestion, + i never been modding 1.5L & below so i dunno wat piston can use, no offence, but honestly i only know much about piston with 81mm and above >.< ...
squintex
squintex
13
ya i read that stuff about bot. but we are trying to play n/a only. we already have L2 turbo for project car hehe
peterj
peterj
1,321
258
1,683
Kuching
woots... i m newbie, not sifu
squintex
squintex
13
apparently theres a friend running perdana v6 piston in his wira 4g15 for already a year and he made 200km/h from KL to JB quite many times and still doesn't have problem. i think its a matter of luck. so anyone can suggest or wanna sell me custom high comp piston 77.5 or less for a cheap price? >:p
rowanromano
rowanromano
30
1,508
hi bro,
u can try:
campro piston kit
s4ph - low comp piston 76mm oem spec (1.6) (willl give u 11-12bar on comp tester)
s4pe - high comp piston 76mm oem spec (1.3) (will give approx 16-18bar on comp tester) (dome piston)
or u might try
s4ph/s4pe 77mm piston
the price roughly rm350-450 including piston ring (proton part center price)
squintex
squintex
13
the car is finished already. used mazda b6 piston dome type. 78mm one. now even gear 5 can reach rpm 7k. quite an accomplishment. i decided not to use perdana v6 piston because its 78.4mm. too big for us. thx for all your help.
squintex
squintex
13
which combo do u mean tofu? im also interested in rowanromano post cuz i've heard ppl talking about that. too bad we already finished the car
sarutobi84
sarutobi84
156
43
Johor Bahru
swift-turbo-malaysia.blogspot.sg
If use pv6 piston maybe can crack if abuse everyday for racing.better use fto piston 78.4 also and high comp.(got bonggol)..
last time sold my fto piston to sp4h campro guy.he say lots of campro guy doing this mode.so means wira should be a problem too....?
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,933
8,363
High compression, the will need RON 97?
15,369
6,405
78mm!!! Wah!!! Did you redo the liners? Isn't 78 already touching the water jackets?
Not necessarily la vr2, can be adjusted via ignition timing. If it's a VDO, it's automatic. Best thing is VDO will adjust based on your octane too so powerrrrrrrrr when you want it.. only bad thing is it takes about a day to self adjust.
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,933
8,363
Mine can't, and when tuned too low the power lost....:banghead:
Kyusuke_FD3S
Kyusuke_FD3S
66
1,508
lol .. it takes about a day to self adjust ...
---------- Post added at 12:36 PM ---------- 6 hour anti-bump limit - Previous post was at 12:35 PM ----------
if 4g15 mod 1.6 stroker kit, the piston remain unchange?
can i assume my engine displacement has increased from 1.5 to 1.6 ?
15,369
6,405
Stroke will increase displacement a bit. But by how much exactly depends on the crank you use, the conrods, etc. Measure it with the cylinder + oil method la. And it might just still be a 1.5++ rather than a 1.6. Since stroke is different you'll definitely feel a torque difference
Beyond 20,000 RPM!
Beyond 20,000 RPM!
29,933
8,363
Depends on the car make. If like old Ford models the 1.3 and 1.6 shares the same piston size, only that 1.6 have longer stroke to increase it's capacity. Long stroke also better low end torque.
For bro. Kyusuke_FD3S, if 1.5 and 1.6 have different piston size the stroke might be the same only...
Dec 6, 2014
johor bahru
hi bro,
u can try:
campro piston kit
or u might try
hi boss,
where can i get these parts?... Do u have a address to catch these toy?.... :proud:
