wheel scratch
gogogo
341
hi,
recently i juct bought a set of rim from friend, and there was some scratch on the rim. so, if i want to remove those scratch is't the only way is 2 send my rim 2 skim? any alternative way other than skim? how much will cost if skim 4 rims? finally, is there any defect 2 the wheel, i mean after skim.
pls advice....
thks & regards
vantageX
103
Never really seen skimmed rims before. But really, its not advisable to do any sort of cutting or skimming to your rims. Rims are stress tested and if you remove any amount or metal or weaken the structure of the rim, you might end up with broken rims and this can be extremely dangerous.
There was an article in one of the Sunday papers today, either NST or Star about this very same question and it is also said there that you should not weld on any more metal to your rim because the heat could warp or place stress on a certain area of the rim.
What you can do however is (and this is gonna take some work and patience) buy some body filler, fill the scratches up and then sand it down till it looks flat with the surrounding area and of course you will have to paint it after that for it to look good. And go easy with the sanding, you don't wanna remove metal as well. This will take a lot of work but its pretty safe and since you're not applying heat or removing/adding metal, it won't damage your wheels. :regular_smile:
gogogo
341
thks 4 the advice bro. appreciate here. any other suggestion.....
spykey
681
agree with vantagex..skimming will put the rims uneven condition because some metal have been skim away..
anyway,the result will look as original n not much $$ spending on skimming..
maybe u can re spray ur rims..although its not solve the scratch prob, at least u can hide it..
guys,
I want to strengthen my car chasis with pump in liquid foam ( will become solid foam after pump into chasis )
anyone know about this?
my question is :
How much is cost ?
where can I get?
Have any side effective after few years?
Pls advise .. Thanks:hmmmm:
