W124 always 'mati enjin' when using ron95
tyj91
tyj91
32
1,508
Hi all sifu's, I have a W124 model 230E, but it is shaky when pumped with ron 95 and hardly ignited especially in the morning. Btw, it can run smooth on ron97 but fuel is expensive.
Anyone know the problem?
Any modifications can be done? Need help from sifu.
Thanks
papagoines
Orang Tua
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
just asking... does your W124 is yours from the start or there's previous owner? reason asking is that maybe the previous owner change the ignition maybe? dunno how... but it could be done rite?
to my knowledge (my father & uncle used to owned one)... it can run RON92 fine (remember the day...)
btw, here's a post in oversea forum.. 91 or 95 octane in 95 W124 E220? [Archive] - Mercedes-Benz Owners' Forums
it says that in their manual runs RON91 minimum... FYI, RON in UK/Euro/AU are the same as Malaysia.
6UE5t
6,000 RPM
6UE5t
6,000 RPM
6,721
1,291
As mentioned above, most Merc engines for W124 especially the smaller ones like yours should have no issues running on just RON91-92 if the engine is healthy and fully std since the compression ratio is still relatively low. In fact RON95 should be very much sufficient already and it does not need RON97 at all!
Check your engine ignition timing and compression again, probably the timing is already set too high/advanced for RON97 and/or the compression might be already a bit high due to too much carbon deposits in the combustion chamber (might need to do carbon cleaning).
Did you hear any knocking/detonation from the engine when using RON95?
BLANk
BLANk
1,750
6,757
Sardine
www.zerotohundred.com
try to check the fuel adjustment plug which located at the batt compartment too...got 2 mark which is S & N on the plug...S for operation with premium grade fuel(ron98) while N for operation with regular grade fuel(below ron98)...just need to fully pull the plug out before doing any adjustment...
