Yup, open pod sucks hot air from engine bay, but your turbo got intercooler. I think the effect not as bad as for NA car, right?good choice bro.. open pod sucks hot air inside ur engine bay.. later when ur trek is 350whp then can change to open pod..
Agree....but at the moment I kinda like drop in since mine a stock car...Any any condition, the stock airbox is adequate for our hot weather/climate usage. Just make sure your airfilter is CLEAN all the time, then you'll be good.
NA sure need CAI already, but 45 degree elbow have a lot of restriction. Should heat up the pipe and bend it, since PU......:hmmmm:i used to work with JB one of the most reputable tuner, and one of his customer's NA drag car used 3" PU pipe (pipe for house sinky grey coloured) for intake pipe n even uses the 45 degree elbow. heheh.. n thats what he explained..
he uses the pu pipe elbow like below.. its a PVC water pipe..NA sure need CAI already, but 45 degree elbow have a lot of restriction. Should heat up the pipe and bend it, since PU......:hmmmm:
what i know about air is that, the hotter the air the harder it to be compress. so our engine had to wrk harder to compress hot air that sucks in..1 thing that I wanna add is that the higher the boost, the higher the air temperature. Compressed air is hot air. Thus the cooler the air is sucked in, the better.. :)
so far they only apply this pvc pipe on NA intake pipe only.. if its melted, then the samco also long time gone already.. and they use to paint it in black so that makes it less look like a household pvc pipe..NA sure need CAI already, but 45 degree elbow have a lot of restriction. Should heat up the pipe and bend it, since PU......:hmmmm:
