Upgrade Oil Pump
Civic Type R
178
21
518
Sarawak
forum.myviclub.com
Mostly ppl will go for Walbro fuel pump.. :smile:
Civic Type R
178
21
518
Sarawak
forum.myviclub.com
Oh.. My bad.. :biggrin:
BabyGodzillaGTi-R
399
7
5,018
For what engine to begin with?
Whats the purpose of upgrading an oil pump for?
If you are talking about RBs i reckon most people would run an aftermarket oil pump from Nismo, Tomei etc u name it.
As for SR20s, most ppl would run a SR16NEOVVL/ GTi-R oil pump.
Don't forget upgrading your oil pan to a bigger capacity oil plan which is also baffled.
For me if budget willing i will go dry sump (factory is wet sump).
Mazworx SR Dry Sump Kit - Engine - Mazworx
You can mount your engine lower for better CG,
oil starvation won't be an issue when racing where one would expect to encounter high Gs when braking, accelerating and taking corners.
And better cooling as you can carry so much engine oil.
If it's a road going car i will follow the principal of KISS. Keep it stock silly.
You want to get a faster car. Safe and invest the $ and upgrade to a better, newer and faster car.
Sorry to be blunt but the truth hurts....
There's no end to modding.
Duke_85
166
KL / Kedah
Thanks bro...
True there is no end to modding but still some people did it.
By the way this is for S15 sr20det.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
if sr20 then just go for sr16vvl oil pump...since that engine running vvl/vtec mechanism which is common to have higher oil pump capacity....
hopeunreal
44
3,008
Just contact James Loo at Onward Motor Sports, (012 218 8910) he has them for your car.
Most of his cars upgrade them.
Many Silvias go there.
The G-Power Typhoon Black Pearl is the latest from the German tuner and its a limited edition model to commemorate the firm's 25th anniversary. And just like ever other G-Power tuned beemer, it's special and fast. <!--more-->
The Typhoon Black Pearl is based on the X5 Typhoon but...
