Taj Mahal restoration - BMW1 series present for the wife anniversary by KC
kc2
1,354
1,410
thedetailers.blogspot.com
I have been head hunted by my old client to help him to get his new car corrected.....
he couldnt sleep upon taking back the car home for his beloved wife as an anniversary gift
I was blessed to be given this opportunity to witnes and correct this car......take a view
oppsssss....
why birds poo is so acidic to our clear coat?
It's important that you remove a bird dropping off your car's finish as fast as you can ... Birds pass their urine into a common chamber used for digestive and urinary wastes. ... So, when a bird lets go with a "bomb" it contains white uric acid crystals ... This type of etching can be removed using a clear coat safe ...
stone chips
swirls.....minor on the hood
UFO landed on the side panel...marring the paint and causing a deep stains...
more RIDs have been found
deep scuffels
Begin with wash - Optimum car shampoo, assisted by OPC
Clay with ONR as lube
Compound Meguairs M101 with Meguairs cutting Foam pad
finish with polish M205 with Meguairs polish foam pads
IPA
Opti coat - body & plastic panel
Opti glass for windscreen
Opti Lense for head lamp
when you shine your Halogen lamp ontoyour paints you will always see what beyond yourbare naked eyes can see
light is themost vital tools of correction beside your rotary/DA/Correction tools
i remembered i done more than just that
finally I managed to scooped up some pictures i had in the other camera
i had this ride for almost 36 hours to get her corrected
always begin from wheels
opss left out
mistake!!!! no problem
its ok to repeat....as long as we get the matter solve
the front panel....veryvery very visible swirls
after compound
on top of the hood
soon you will discover a major work
swirls from improper wash
major major
tadaaaaaaaaaaaaa
tadaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
more swirls
before
ta daaaaaaaaaaaaaaaa
side body
before
tadaaaaaaa
close up
before
after
tadaaaaaaaaaaaaaaa
tadaaaaaaaaaaaaa
passenger door
another major side
before
after
before
\after
before calling a night
amazing how the metalic flake popping out again
many hours later
hmm...my new passion.....
TADA is a reflection
again
ta da
before
after careful paint correction
before
now
mamamia
minor swirls before
and now awesome paint flakes flaoting out like the many stars in the skies
the hood
the close up pic of the hood
ladies and gentlemen
presenting you the new 1 Series 116i
by this time you probably knew it is near sunset........
nice day
ta da ...reflection of the d panel
luster...deep ...wet......looks after proper paint correction
i would like to let the pictures speak for her self...please enjoy a wet dripping black
Thanks for viewing yet another of my detailing journal, i am blessed to give a hand to Henry (in making this Taj Mahal for his beloved wife
If your cars need a Scanner Reader, which one you think will be better? As following:
The first one Scanner Reader SC16 GS500 OBD2 II
Specifications:
Codos Scanner Reader SC16 GS500 OBD2 II - DinoDirect.com
The second one : OBD2 Live PCM Data Code Reader Scanner D900
Specifications...
