Subaru Legacy BP5/BL5
DeaconFrost
284
159
1,543
Pics:
JDM spec.B aluminium front lower arms:
Subaru Legacy 'Applied Model' Code Guide (source):
1: Platform
B - Legacy/Outback
2: Chassis
L - 4th Generation Sedan
P - 4th Generation Wagon
3: Powertrain
5 - 2.0L AWD
9 - 2.5L AWD
4: MY/Type
A - US: 2005 JDM/EDM: 2003, 2004
B - US: 2006 JDM/EDM: 2005
C - US: 2007 JDM/EDM: 2006
D - US: 2008 JDM/EDM: 2007
E - US: 2009 JDM/EDM: 2008
F - JDM/EDM: 2009
5: Destination
4 - RHD 4 Door (Sedan) from FHI
5 - RHD 5 Door (Wagon) from FHI
K - RHD “General Market”
L - LHD “General Market”
Y - LHD for US/Canada/Taiwan from SIA
6: Grade
2 - Japan: 2.0i Casual Edition
4 - Japan: 2.0i
7 - Japan: 2.0R Wagon
8 - US: 2.5GT Limited EDM: 2.0R-C
9 - US: Outback 2.5XT Limited Japan: 2.0R Sedan EDM: 2.0R
A - US: Outback 2.5XT
B - Japan: 2.0GT Sedan EDM: 2.0GT / 2.0TD
C - US: 2.5GT Limited Japan: 2.0GT spec.B Sedan EDM: 2.0GT-X
D - US: Outback 2.5XT Limited
E - US: 2.5GT Japan: 2.0GT Custom edition EDM: 2.0GT
F - US: 2.5GT spec.B Japan: 2.0GT Wagon EDM: 2.0GT spec.B
G - Japan: 2.0GT spec.B Wagon
H - US: 2.5i EDM: 2.0i / 2.5i
J - US: 2.5i Base EDM: 2.5i
K - US: 2.5i Limited
L - US: 3.0R Limited Japan: 3.0R Ivory Leather Sedan EDM: 3.0R
M - Japan: 3.0R Sedan EDM: 3.0R-A / 3.0R spec.B
N - US: 3.0R Japan: 3.0R Ivory Leather Wagon EDM: 3.0R / 3.0R-C
P - US: Outback 2.5 Base Japan: 3.0R Wagon EDM: 3.0R-A
R - Japan: Outback 2.5i EDM: Outback 2.0TD
S - US: Outback 2.5i Japan: Outback 2.5i Ivory Leather EDM: Outback 2.5i
T - US: Outback 2.5i Limited EDM: Outback 2.5i-C
U - US: Outback 3.0R EDM: Outback 3.0R
V - US: Outback 3.0R Limited Japan: Outback 3.0R EDM: Outback 3.0R / Outback 3.0R-C
W - US: Outback 3.0R Lim-LLBean Japan: Outback 3.0R Ivory Leather EDM: Outback 3.0R / Outback 3.0R-A
X - US: Outback 3.0R LLBean Japan: 3.0R ADA Wagon
Y - Japan: 3.0R ADA Ivory Leather Wagon
7: Drivetrain
9 - SOHC NA CVT
A - DOHC NA 5MT (1st and 2nd gen) / 6MT (5th gen)
C - DOHC NA CVT
D - DOHC Turbo 5MT
E - DOHC NA 4EAT AWD
F - DOHC NA 5MT Dual Range
G - SOHC NA 5MT
H - DOHC Turbo 6MT
J - SOHC NA 5MT
K - SOHC NA 5MT Dual Range
P - DOHC Turbo 4EAT VDC
R - SOHC NA 4EAT VDC
S - DOHC NA 4EAT-Sportshift
T - DOHC Turbo 4EAT-Sportshift VDC
L - SOHC NA 4EAT-Sportshift
M - DOHC NA 5MT
N - DOHC NA 6MT
U - DOHC NA 5EAT-Sportshift
V - DOHC Turbo 5EAT-Sportshift
W - DOHC NA 5MT Dual Range
X - DOHC Turbo 6MT
Y - DOHC CDI 5MT
Fuel Consumption:
Fuel brand: Shell FuelSave 95
Car: 2.5 GT MI spec
Fill up: with 70km worth of fuel left
Refill: with 70km worth of fuel left
SI Drive mode: Sport
Distance travelled: 435.6km
Fuel quantity: 51.45 litre
L/100km: 11.81 (50% urban, 50% highway)
Fuel brand: Caltex Premium 95 with Techron
Car: 2.5 GT MI spec
Refill: with 60km worth of fuel left
Distance travelled: 431.7km
Fuel quantity: 52.17 litre
L/100km: 12.08 (60% urban, 40% highway)
Fuel Requirement:
MI Spec: RON 95
JDM Spec: RON 97
Wheel Fitment:
17 x 7, offset +55 - MI 2.5 GT stock wheel
17 x 9, offset +30 - poked front & rear, rubbed at the rear
17 x 7.5, offset +42 - flush at front, doesn't rub
18 x 7, offset +53 - JDM spec.B stock wheel
Maintenance:
Timing belt kit: Subaru OEM vs. Gates with Japan-made water pump: RM2k+ diff between them.
Normal maintenance: +-RM300 every 5k km
Gearbox + F/R differential oils: +-RM500 every 25K km
Power steering pump: New Subaru OEM RM2k+, chop shop RM1.8k (AE)
Known Problem:
1. Power steering feels heavier during parking
Manuals:
http://justgivemethedamnmanual.com/subaru/subaru-legacy-owners-manuals/
Information contributed by:
Dayline668, DeaconFrost
Dayline668
1,810
492
1,683
1)BP5 is 2.0, BP9 is 2.5 no matter legacy or outback. Outback has higher ground clearance for off-roading.
2)No, spec-b means bilstein suspension, lower n sportier with added accessories.
3)EJ25D no turbo only put out 165ps. JDM EJ20X/Y with 265bhp A/T, 280bhp M/T.
Get a JDM spec-b u get more then a normal GT model.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Hi Subaru otais,
Just would like to know:
1. Excluding the S402s, are there JDM Legacy codenamed BP9? Or is the code only meant for JDM Outbacks (higher ground clearance than BP5 Legacy/less sportier)?
2. Is there an Outback spec.B?
3. Does the EJ25D make 250ps, while the EJ20X/EJ20Y on BP5/BL5 make 265ps?
I'm also looking for a 2nd hand 2004 Legacy BP5 Luxury or spec.B, preferably black. If you guys know any unit for sale, kindly PM. Thanks.
so far none up for sale i saw...but a few on road...
DeaconFrost
284
159
1,543
Thank you brother.
Is there a spec.B with sunroof?
Dayline668
1,810
492
1,683
Thank you brother.
Yes.. mine with moonroof.
Thanks bro, saw the ad but I don't think that's a spec.B right?
Not sure if that is a McIntosh player installed in the car.
Mc system is option when u purchase new car so is not specific on spec-b only, mine normal 6cd player. Spec-b original came with 18'' rim, front rear aluminum lower arm, aluminum padel, bilstein suspension with stiffer spring.
DeaconFrost
284
159
1,543
Thank you brother very useful information there.
Can I say the easiest way to know whether a car is a spec.B is whether it has aluminium pedals & Bilstein suspension?
Should I look for any special codes on the VIN?
Dayline668
1,810
492
1,683
Bilstein suspension can be install, but aluminum lower arm is the most expensive part, so should confirm a spec-b by that. Double check the "Applied model" online then u can confirm its a spec-b, Mine was BP5A5GV, diff year have diff no, BP5 ''A-E'' A=2003 till E=07/08, ''5GV'' is spec.
This is the full set aluminum arm only on spec-b.
DeaconFrost
284
159
1,543
Dayline668
1,810
492
1,683
2.0 diesel turbo not 2.5. No SI-drive only E-4AT n manual 5sp for diesel. That SG car is petrol.
Dayline668
1,810
492
1,683
Hi. Would the ZTH members share their pricing regarding this services below. I don't wanna get cheated so i would appreciate your help. My car is perdana sei.
How much is it for :
Pumping Front Cambers
Pumping Rear Cambers
Alignment
Balancing
Nitrogen
I would really appreciate your help for these info and let it be shared so that people out there won't get cheated.
Do quote me the price for pumping of front and rear cambers for perdana. Thx. :)
