Rotary Engines - FAQ.
anand raj
82
4
508
erkks, Dont tell me needs a rebuild man, Very hard to find a good sifu to repair rotary now, I went 2 shops allready they just tune it up tell all ok ady , i really have no idea where i can get a true answer ......
savahn
323
60
anand raj: bring your car to ah choy to check up. Sounds like old age :)
Regarding rebuilds - just go to Ah Choy. His senior team people - Ah Hau and Ah Seong, now has a lot of experience regarding this. And his team are very disciplined and hard working ppl.
Devil_Z RX
Jun 6, 2011
13
Seremban
Hi..
Im still new with the rotary engine, so i want to ask the otai2 here about sumthing regarding rx7. What is the best rpm reading when in idle mode for rx7? cuz i saw one of this rx7 which in idle mode is 1500rpm, is it normal or not for the rotary engine?
Alchemis
1,416
47
1,648
1500 is not a good RPM.... you should be idling at 900rpm... 1500 rpm probably the mechanic adjust for you as they can't balance at 900rpm... send to a reputable rotary builder and they will sort it for you...
causes of unstable idle is the adjustment of bleed in the manifold, worn spark plug, bad tuning, bad compression, vacuum leak... it can be ANYTHING...
adamckc
129
19
that anything .... is the most scarry part.. especially engine rebuilt..
adamckc
129
19
i saw from paultan site mazda japan may stop new rotary engine research,, ie the end of new rx9 or something,, so sad...
Ry0suke
55
10
1,508
omg this news really hurts >.<
adamckc
129
19
but then maybe no more new model makes the old model 7 and 8 appreciate in value.. possible?
Ry0suke
55
10
1,508
yeah probably.... but it still saddens me if they stop the development of a new rotary engine T.T
That'll probably be the death blow to a very exciting piece of engineering T.T
adamckc
129
19
exactly,, where on earth to find an engine 140 kg producing more hp than v6 300kg weight,, bloody clever technology... so many rotary heads going to sob..only thing once in a while has to spend big buck for rebuilt as the apex seal kong off.. like what i am doing now..
Anyone sells hotbits full piping set for BLM? how much. Brand new please, and PM me your best price. thank you.
