Rm8k Wira & Jazz GK5 ownership experience-A long way to go
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Eh?I only open up & down once so fast panas ? Oh my... hahahahhahaha
My Pajero have similar problem. Can go down but sometimes cant go up. Have to toggle the switch down then up multiple times. I can hear the switch/relay clicking. Only happen for UP function.
Always forgot abt this problem as most of the time i drive the Pajero with aircond ON or air vent open.
Another thing I would like to ask is the power window...
Sometimes it go down then suddenly cannot go up. Need to wait for a minute then press only can go up. Is it the motor rosak or some wire malfunction?
check the switches itself. Considering how old the car is, potentially contact not so good. If you are a good DIY-er you can dismantle the switches to clean the contacts and all. If you aren't good then try replacing it. I think it's not too expensive anyway.
But this is assuming your window motor and wiring is nice and tidy. Does your door still have the water protection in place? check the wiring and motor to see if rust or something has corroded contact.
lsm1991
1,469
185
PJ
eh u same problem as me... mine no wan go down... can hear relay clicking
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
what do u think...relay?
There is clicking sound so switch should be ok as its sending power to the relay till it clicks.I doubt its the motor as it can go down anytime.
BTW if u saw a guy driving a pajero in the rain with driver side window down and only his left hand on the steering..thats me. My right hand is not busy being naughty in my pants but frantically toggling the power window switch..hahahha.
parakey
1,367
226
663
You are in a Pajero. I have to be pretty high up to see your left hand on steering. :biggrin:
Why dont you just replace the switch?
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
kinda expensive (120-200) as its a very old car and such part is getting harder to find. Its one set with all other window switches.
parakey
1,367
226
663
Bro, compared to getting drenched on a rainy day, rm120-200 suddenly dont seem that expensive anymore.
Alternately, it's just a switch. You can mod a similar but cheaper switch from another model into your car.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
its an offroader. Rain is like going to the carwash...hihihi.
Was thinking on modding a normal switch but i will lose the auto down function...yes, the old pajero got auto down for driver side. Even my supposedly modern BLM dont have that.
I'll do proper diagnose this weekend.
KHNG940413
668
56
528
johor bahru
Wira update
Now the car is running nice and mange to range around 420km+ per tank (Rm55+ per tank
Now what I found out the exhaust while idling have some weird noise. Like thin sheet of metal shaking.
Like sok sok sok sok sound.
Didn't affect me anytime,juz abit annoying.
Wira update
Check along the whole exhaust piping, there are heat shields spot welded on, along the way. Maybe one of them, a spot came loose and vibrating. My Chery SUV had that problem. Initially thought a piece of Cat Con internal broke loose and jumping inside the cat, but later jack up the car and start the engine, found the heat shield vibrating....
minibeany
598
102
543
Wira update
sok... sok... sok... sound maybe a hole... check also any surface that has pimple
minibeany
598
102
543
add full coolant first. let the rust all tanggal and floating. then take out coolant and flush with running water. add again coolant and let it run again. repeat with running water. LOL
as per instructed... just tried this method with the radiator flusher... it just too strong for an old radiator... it flush the whole radiator out from the engine bay... hahaha... radiator leaking now.... wasted my coolant.
  • Wow
Reactions: Izso
Dear Mr FocalPoint,
I am thrilled to read so many good reviews about Tufoil. Since I am staying in Shah Alam, I would appreciate if you can share your distributor's address & contact number located in Shah Alam.
I am planning to pour my 1st Tufoil into my 11 years old 660 Perodua Kancil engine.
Your kind assistance is greatly appreciated.
Thank you
