Rm8k Wira & Jazz GK5 ownership experience-A long way to go
parakey
1,367
226
663
In my opinion, if the new sensor is faulty, it wouldnt start even foronce.
Since your's does start occasionally, I reckon the sensor is okay. That being the case, the wiring and the connectors are highly suspect
KHNG940413
668
56
528
johor bahru
Maybe is the connector that connect to the crank sensor got problem?
Someone juz recommend me just took off both socket & connecter and just direct both wire.
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
The wire condition is all ok. The mechanic had check,I had check myself also. Really fadeup. Hahahaha. Tomorrow will ask my friend got multimeter or not to test.
I wont buy a new sensor yet.
Just like others said, its bad connection or wiring somewhere.
Even if u cable tie a connector the male-female connection of the pin inside connector might still have connection issue.
However during early ownership of my waja, i do face crank sensor issue. Its a common issue among waja 1.8 owners where engine will just die off when cruising. Leave it to cool down, it runs back as if nothing happen. I went thru 2 sensor and the 3rd one lasted me till today. Maybe they upgraded the sensor. My sensor is hidden thus not exposed to the element.
Other exp i encounter related to bad wiring connection is check engine turn on and engine becomes abnornal after driving over uneven surface. Turns out the battery terminal is loose. The bolt on the terminal is tight but terminal can moved freely. How to solved? buy a new cable terminal or wedge copper piece or any conductive metal between the battery terminal and cable lug.
Recent exp with my waja abt bad grounding tought me a lot. Its not abt how the wire appear visually, its about the contact that its making. Removing the wire from the ground terminal at the battery showed very bad corrosion. How to solve? in my case, i went to a machinery shop and buy welding cables. If u want to do this, please dont buy cables dedicated for welding purpose coz the insulator is very thick and will be hard for u to positioned it properly. There are similar amp cable with not so thick insulator for sale. These typenare easier to worked with
  • Like
Reactions: KHNG940413
This is my crank sensor position.
Tomorrow will go and source the original sensor.
If can ok la,if not I really wan to ditch the vdo and slam the mmc inside.
Is not like mmc will not have issue lah but less sensor issue is better for me to maintain the car at my rough working environment. My 2cent la.
wait... what sensor are you using right now? Not a proton sensor? You pnp a crank sensor from a different car?
Did your mech open up the ECU to check the ECU board itself?
EDIT : I just had a thought. Is your crank pulley ok? Mine at one point wobbled really badly because of the rubber dampener had worn out and that shaked the whole damn crank pulley so maybe if yours is moving too then the sensor isn't getting a good reading.
KHNG940413
668
56
528
johor bahru
3rd party one. From china one.
Nope he didn't open the ecu because he don't have those equipment to do so
Did you see my comment about the wobbly crank pulley? You should be able to visually inspect the pulley. Start the car and look at the pulley turn. If it wobbles then you potentially have your culprit.
China crank sensor - but was it made for your specific engine or a generic VDO sensor?
KHNG940413
668
56
528
johor bahru
I have start the engine and inspect. Didn't have any wobble.
Yesterday I checked and try wobble the crank sensor itself at the bottom side and the car died same as the car usually went dead.
Not sure as I never see the package.
parakey
1,367
226
663
Use my hand and goyang like pusing your kopi while the milk is at the bottom. Hahahahhaha
Not very hard juz slightly goyang only
There's a reason why I asked. The sensor's position relative to the trigger wheel is supposed to be quite immovable. It cannot be "longgar" to the extent where a small force may deflect it. This will cause the sensor to miss a read and stall the engine.
Have you gotten a multimeter yet? Check to see if sensors are really faulty.
  • Like
Reactions: Izso
KHNG940413
668
56
528
johor bahru
So what you mean is maybe my sensor is crooked is it?
i remembered I did saw a pic that shows a kancil with the 1300cc K3-VET engine. I would like to ask is that really possible? No problem with the JPJ?
So one K3-VET + installation worksmanship is how much? I also need BOV, intercooler, turbo timer, piggyback ecu remap and all this dashboard meter thingie.....
So if we can install the engine, what about the gearbox? can install also? I wondered if it has CVT..... Also I would like to ask if we can strengthen the gearbox and install...
