My VR one broke and replace with a solid metal one without the sleeve.....Plus if you do get the LCP you'll need to get one with a reinforced center sleeve cuz the full alu ones will deform after a while cuz no dampening.
solid steel or alu?My VR one broke and replace with a solid metal one without the sleeve.....![]()
Solid steel, mechanic say this one won't come apart.......hhahhahahhahahhasolid steel or alu?
Usually those alu pulleys have solid steel sleeves. Yours is fully solid steel - sure la. Isn't it heavy though?Solid steel, mechanic say this one won't come apart.......hhahhahahhahahha
No difference since original also steel, only have rubber sleeve.....Usually those alu pulleys have solid steel sleeves. Yours is fully solid steel - sure la. Isn't it heavy though?
Check for vacuum hose leak and your distributorHi sifus. Really need some help here. Just when I thought my car is in very good shape, it failed on me today.
For context, my car is 1996 Wira 1.5 Carburetor (Automatic).
2 days ago my car was still running fine. Made a trip from Cheras to Bukit Jelutong, car had no problem at all.
This morning, started my car as usual and then started my journey. The moment I stepped on the accelerator, I knew something was wrong. The car felt very very sluggish. It wouldn't accelerate much despite me stepping on the gas pedal harder than usual. I am familiar with this car so I know what to expect when I apply a certain amount of pressure to the pedal.
Drove on Federal highway and my car struggled to even reach 80km/h despite me pressing harder than usual. Mechanic changed engine oil (it was due for a change anyway), fuel filter, air filter, spark plugs. Told him to check my brakes but all were OK.
End up still same problem. I think my mechanic doesn't know what is the usual pressure to apply to get the car to certain speed so he doesn't really get my problem. Mechanic told me to monitor my engine oil level as when he drained my engine oil, it was less than half of the required oil. My last oil change was in February. He said maybe my engine makan minyak so have to monitor and see.
When the car is idling, there was no unusual sound. No white smoke. I did rev the engine and I noted something very different than usual. The response of the RPM is much slower. If last time I tapped the gas pedal and let go, the RPM will respond fast by going up and down again. Now, there is a 'lag'. Takes a while for RPM to go up and down after I give the pedal a quick tap.
What are the potential problems im looking at here? Is it carburetor? Or engine? Throttle cable? Basically my problem now is that my car seems to have lost 'power' in just a matter of 2 days. Suddenly press gas pedal but the power is not like how it was just 2 days ago. Difference is like night and day.
Thanks sifus
Two sifus already responded.Hi sifus. Really need some help here. Just when I thought my car is in very good shape, it failed on me today.
Thanks sifus
Ok, i'll be sure to ask the mechanic to check these. Thanks!Check for vacuum hose leak and your distributor
Sounds like a plan. Do you have any recommendations for KL/Selangor area?Change mechanic, you need one who knows how to tune carb.....
1. ok, will ask the next mechanic to check for that.Two sifus already responded.
1. Considering the age of the car, check for cracked vacuum hoses. All are made of rubber so they are prone to wear and considering the age of your car, it's potentially the culprit.
2. The carb tuning went out of tune. Screw loose? I don't know enough about carbs to comment. Find a mech who knows how to tune a carb to check.
3. When was the last time you changed spark plugs?
4. Have you ever changed your petrol filter?
5. Do you still have a catalytic converter? How old is it if yes? Maybe you need a catcon cleaner additive from Bluechem. Or remove the catcon altogether.
6. How old is your distributor? Spark plug cables?
7. Also if your car is burning so much oil there should be some sort of smoke coming out of the exhaust. Use a piece of white tissue or paper and cover the exhaust and see if you see any black stains or oil stains or something.
I find it hard to believe your mech is not carb competent unless he's some young kid below the age of 35. The guy I know who can tune a carb has already retired. hahaha..Ok, i'll be sure to ask the mechanic to check these. Thanks!
2. Any recommendations for carb tuner in KL/Selangor area?
3&4: Yesterday I changed both. But the sluggishness still remained
5: No idea, but if I do, then it probably hasnt been changed at all.
6: again, not sure (i just took over this car from parents last year). but i would say these 2 havent been changed for at leatst 6-7 years as far as I can remember.
7. ok, will do that and see!
Thanks so much. So I guess the aim now is to find a mechanic that can tune carburetor first, and then see how it goes. Am busy these few days, so will likely have to drive the car in current state to run my errands. Earliest also next monday only can go find mech again.
He's mid 40s at least. I've yet to call him and explain that there's no improvement. The changing of spark plugs, etc was just regular maintenance. Planning to call him and ask him again.I find it hard to believe your mech is not carb competent unless he's some young kid below the age of 35. The guy I know who can tune a carb has already retired. hahaha..
Incidentally - if it's inherited from parents, have you considered trading it in for perhaps a newer easier to maintain car?
If you want to try, my mechanic since my Carb Civic and Carb Accord, did my VR4 transplant also and is still my current mechanic...lolSounds like a plan. Do you have any recommendations for KL/Selangor area?
Do you have a picture of the said crack?And also found out the bottom front body have some crack....is at where the front crossmember & the body screw up one.
Later jack the car up will take a pictureDo you have a picture of the said crack?
Crack like this. Is quite worst to be honestDo you have a picture of the said crack?
That looks bad, sure need to weld back......Crack like this. Is quite worst to be honest
Later got time will go and ask can it be weld back by add some metal plate.That looks bad, sure need to weld back......
Thread starter | Similar threads | Forum | Replies | Date |
C | Wira issues | Car Talk | 25 | |
Y | Proton wira 1.5GLi need help!! | Car Talk | 3 | |
S | Wira SE bumpers | Car Talk | 6 | |
K | Timing setting for Wira 1.5 GLi | Car Talk | 2 | |
A | Proton wira 1.5 (1997 auto) engine heating problem | Car Talk | 12 |
