Raytech Puchong, Bad Experience - RESOLVED
RB26
GoKart Lover
130
76
5,028
selayang
www.mangoesteen.net
Bad tinting experiance today at Raytech Tinting puchong.
Dont know what they did and causing my brake light faulty. Didnt press the brake but the light keep ON.
ask them what happen Tai Chi me to check with Kia SC because my brake switch got problem. Not their fault. No choice I have to immediately drove to Kia SC for checking. they cant figure out what happen and advice me come on Monday for full cehcking as already 6PM saturday now. So i drove home my car with brake light on ALL THE WAY. And have to unplug brake fuse to not drain my car battery when over night.
I try to un-plug & re-plug the brake light switch @ the brake pedal and problem still same. Appearantly not the brake switch problem. Suspect was the water from into dashboard and kena some wiring. Tomorrow try expose the car to sun see if can help.
Hi guys, After putting my under sun, everything back to normal. which is my brake doesn have any issue at all. And Raytech call and made apologize. I hope they will improve their worker profession in the future. TQ
BeCool
241
29
May b you can try to buy Thirsty "Hippo Moisture Absorber" from giant/tesco and put in car whole night nearby the brake light area.
Else there might be a small piece of rubber worn out between the brake pedal and the brake switch. Happen to my few cars. And problem solve after adding a small nut into it.
RB26
GoKart Lover
130
76
5,028
selayang
www.mangoesteen.net
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
713
I think I understand what happened.
Tint installers use water spray to align the tint on your window before they stick on it permanently.
They will wipe the water away, maybe inside the window regulator for the side windows' for example.
Maybe it seeped through there. Like that Kia quality kinda bad eh. Since all tints are installed that way.
  • Like
Reactions: alcyon
Problem has been amicably resolved by the complainee and the shop.
Closing thread to prevent further unnecessary banter.
Hi guys. First time posting here even though I had registered since 2014 (I can't even remember that I had registered already lol)
Anyway, earlier this year I bought a 1997 Proton Putra. Originally the car was an auto transmission but the previous owner had converted it into manual transmission. The car was almost in stock condition except for some parts such as
1. Rims
2. Gearbox (using F5M221 code). I believe it is the same gearbox used by Proton Wira 2.0 Diesel
3. Front hood (Ah Beng...
