Racing Harness
EG9
2,309
37
Subang Jaya
what kind of hardness that u're using? can just mout on original safety belt point.
integramania
2,336
where is this located...coz you need to mount the back portion to something that is directly behind it in a straight line...meaning like a loop of some sort...by the way its a Sabelt...only if it was longer than ok ler I can attach it to my rear strut bar
sta
639
i have seen b4, a wira mounted to the rear bar inside the boot.
but not practical because then ppl cannont sit in the back seat.
i think u can fix a room bar in the rear passenger footwell and attach the harness to it.
whatdamn
1,344
Cheras, KL, Mal
integramania,
locate the seat belt buckle points under the rear passanger seat. there should be 5 or 6. these threaded holes are where you should bolt the eyebolts provided with ur harness. recommended is always a criss cross placement of the harness (ie. one overlapping the other to form an 'X').
V-Spec
1,861
170
5,163
Aren't harness supposed to be mounted in a 45 degrees angle.
khoyos
2,632
156
5,163
Shah Alam
Dremel said:
Guys.. any idea where to get eyebolts?
as the name suggested, u can get it from nut n bolt shop. cost rm2.50 each. u need 4 (2 for sides, 2 for the back). there's a nut n bolt shop in padang jawa, klang.
Dremel
1,036
Ampng Nrdschlff
Actually, I went to a few nut/bolt shop but most of the eyebolts don't match since the sleeving is different.
Anyway.. Thanks for the input. I'll try to look for it at the place you've mentioned.
khoyos
2,632
156
5,163
Shah Alam
easy. buy a nut that fits the eyebolt. weld the nut to ur floor. then u can fasten the eyebolt to the nut. a nut cost 20cent only hehehe
integramania
2,336
Dremel....hello bro....now using Bride full bucket for a change....bloody hard to get in and out....
Sorry ah can anyone post a pic of this eye bolt... can't seem to picture it
just a round looking thing that can allow the clip to fit in?
You can now be a part of history as Shell Malaysia is now hosting the Global Shell FuelSave Day in an attempt to set a Guinness World Record for the the Largest Fuel Efficiency Lesson 15th October 2011 - Saturday at the One Utama Shopping Centre.
The Global Shell FuelSave Day is in ongoing international campaign to assist all drivers in saving fuel and money.
It is an educational opportunity to learn the best ways to save on driving costs. It is a 30-minute interactive training session...
