Perdana Evo 3 - engine oil splatter out
kurt_629
872
54
528
johor
What boost were you on? 1.1?
What boost were you on? last time i use 10w40 boosting would make my EO less, tried 10w60 ,EO level remains. but expensive la..hard to find 10w50/60. :smokin:
only 0.9 bar, max for a stock engine..
I also using 10w40, shell helix
Beyond 20,000 RPM!
29,998
noted..i'll stick with 0.9bar then..hahah
I'm avoiding castrol like plague, used to use magnatec before change to shell semi @6a12 engine..better butt feel with shell compare to castrol.:love:
The other I know is Chemlube 10w-50 but that will be expensive....:smokin:
pac_jb
131
518
think the oil splatter out from the dip stick.
any abnormal issue on your engine?
The oil splattered from the back of the engine, no any oil at the front of the engine, recently there were no any abnormal issues with the engine, but there have been misfire when the engine is warmed up
pac_jb
131
518
I just came back from workshop, oil leak from the headgasket, changing the metalgasket and changing headstud to ARP stud.
Computer-generated image of the RWD Coupe.
Don't dismiss Hyundai as "just another Korean car maker", the Korean company is rolling out its new RWD BH-platform on which the new Coupe will be based on. The model name for the Coupe is not confirmed yet but it is rumored that it will be called the Tiburon.
Just look at those...
