not again!!!
morgan
71
recently juz plonked in a gsr rs.according to my friends if it is a gsr rs the intercooler, turbine and injector are evo 1 is it true??mine its only the i/c which is vr4-rs thats all....anyway is there anything such as gsr rs???damm disappointed n bought it for RM7000..!!!!!!!!!!
mag9556
2,770
43
1,648
Morgan,
What u said is yes, as this engine have 210 hp stock.
Not sure about the engine spec but these engine comes with evo intercooler.
Try to check it at the market.. hehe..
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
some say there's no such thing as gsr rs.which 1 is true i also don't know.
i know that there is a 210 hp gsr.blurry about this topic.
huakenny
LB Performance
9,126
240
3,163
Kota Kinabalu
i gues urs is normal gsrt, where the Intercooler is located at the driver side rite? small one...if i not mistaken.
saw my fren bought one half cut...gsr as well for his wira but the intercooler is at center....like evo...he tol me it is newer version and has extra HP....i not sure it is gsr rs o not...he jus told me newer version.....
khoyos
2,632
156
5,163
Shah Alam
even if there is actually a gsr rs, it wont come with evo1 injectors n turbo. intercooler maybe yes.
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
if we look at the history of RS version from mitsu car,there's a lot of
differences with the so call gsr RS.for example,RS usually lighter then
the gsr.thinner door glass n windscreen.no rear wiper.no sound
proofing.no power windows.even the wheel's come in steel in smaller
size.sometime's i even heard my friend who work at a chop shop
telling me that the so call gsr RS actually a wagon turbo.:confused_smile:
really confusing.hehehehe.......
Harith
553
B.B.B
bro i think the one you refer to is the libero GT model...(wagon)
not alot different from normal gsr...
just that td04 turbine is a twin fin and its fitted with an evo i/c...
this type of model has the CD5W chasis number..
only auto libero halfcut has reach our shore... no manual tranny yet..(to my knowledge)...
pesonally im using this engine in my wira... and there are couple of things that need to be mod before can put in the wira chasis...(steering rack cant be use bracket too big and piping from i/c to intake is short... dont know somehow when i put the engine into a wira the engine itself is lower then in the original chasis...
Picture of 1994 - 1999 Libero wagon:-
Libero Spec:-
Libero 1999 Spec Sheet
cheers...
raja_emeperor
741
28
actually there is a gsr rs version.
1.more lightened body.
2.roll bar thicker than normal.
3.manual aircond
4.manual window.
5.evo1 intercooler
6.bigger piston.(sorry forget the sizes)
7.diff ecu code.
8.got extra 1 hole inside the timing belt area.not sure what this hole for?
i know this bcos i changed my stock gsr piston to rs piston.comfirmed! rs version is not a myth.
Harith
553
B.B.B
as what ive heard from alot of mech...
gsr rs is a wagon (CD5W) or normal (CD5A) gsr that has been mod my the previous japan owner...
so when it reach our halfcut place they call it rs spec...
i dont really think that gsr can fit evo piston because as
i know that gsr has a 81mm piston diameter and evo has 85mm diameter...
there is no way that you can do this because theres not enough room between the cylinders to take 4mm out of each one...
Dont matter what year the gsr is from (CM5A, CD5W, or CD5A) all have the same bore/stroke
does anyone know what chassis number the rs version is from?...
is the rs piston forged? or just normal but different size?...
no solid proof that the rs version does or doesnt exist...
just my 2 cent...
cheers....
kennethfong
506
harith,
i'm using the libero GSR CD5W, but mine comes with mini intercooler!! and it's an auto tranny (though i combine this with my pre-existing japanese 4G93NA 2 wheel F5M222RRKE galant gearbox)......ECU Code is 7377 but now lying in my store room unused.... dunno bout the steering rack bracket thing coz i left it for my mech to sort it out......
Harith
553
B.B.B
CD5W with a mini intercooler (side mount?)...
mine also CD5W auto with ecu code 5070...
i will refer to the ppl in 4g93t.net with this ...:-)
personally i never seen CD5W from libero chassis fitted with a side mount...
i think later model libero is using some lancer item....
kennethwong:- now you using what ecu....?
kennethfong
506
harith,
ya it's a side mount mini intercooler, it's a CD5W wagon, coz i took a good look at the original steel tag at the engine firewall area before i did my transplant... now proudly a megasquirt owner, like khoyos' monster (but mine no where near his haha)....
Harith
553
B.B.B
The 7377 ecu you have is the one that cant chipped because there is no EPROM socket on the board...
i think later model libero is using some lancer item.... that why ive tried the steering rack on wajaand it can be use... dunno why...
kennethfong
506
harith,
me now using megasquirt, it's a new DIY standalone from US....so if my 7377 can't be rechipped, it's as good as no value?
Harith
553
B.B.B
yeap it cant be chipped...
but now you already using ms...
nice nice...
im waiting for my budget for a standalone...
how is the ms treating your car ...? good?
cheers...
Hey guys, My airconditioning isn't blowing nearly as powerful as it should. At maxium speed its equivilent to maybe #1 speed or 2 on most vehicles. Im assuming its my air cabin filter thats clogged and would like to check it. However, im unaware to where its located in the 1999 mitsubishi lancer. I have checked the engine bay, under the dash and behind the glove box. Im still not seeing it unless im missing it. Plz help guys. :biggrin:
---------- Post added at 06:23...
