Newbee with airtrek T, can run on RON95 ? really need to remap to use ron 95?
badguy
951
Remap ecu is possible, im not sure what are airtrek ecu code, but you can confirm with the tuner beforehand.
I remap my stock evo3 ecu + replace the chip + dyno tune (mainline dyno) about rm7xx. Launch control additional rm50 with wiring.
btw, your aitrek is fwd or awd?
arent airtrek 4g63t engine...4 liter should suffice if there is no engine oil cooler.
where u remap ur ECU?
my airtrek is awd
badguy
951
Yup, de-tuned evo 7 engine but terbalik from VR, and evo 1 to 3. Google and many say 5.1L :confused::dontknow:
that's y i ask here from Internet some spec say 4.6L
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
hi all sifu here,
i will get my airtrek turbo soon
can i pump RON 95 for this car?
do i need to remap ECU to use ron 95?
as i know after remap HP sure reduce, is ok for me
after remap to use RON 95
can i flood the pedal?
Airtrek turbo can use ron95 from factory as it was tuned to run on ron95. stock map are running on much rich side to protect fuel starvation or overboost. so a lot of my airtrek friends do reflash tune to run more efficient FC and more power (on demand). there are few names of reflash tuner for airtrek/evo. where do u live?
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
airtrek turbo needs 4.5L (approx.) for engine oil and recommend to use 40 series viscosity or higher as per mileage increase. and yes airtrek turbo are also 4G63 turbo which the engine taken from Evo 5 and gearbox from evo 7.5 gta while turbo is a TD04HL shares with RVR 2nd gen. running on 450cc injector (high impedance) and a very2 mild (lemau) camshaft duration/lift. stock boost should be around 0.6~0.7 bar and should should run healthy 1 bar with or without ecu tuning.
Finally got airtrek sifu come in......:driver:
  • Like
Reactions: 4gbanger
stutzedward
3,416
561
Yes the otai here are all correct on their comments. Unless your Airtrek is recond from Japan, most we see on the road are imported locally by USF (I think) and they're mapped to run Ron95.
When mine was stock with no mods at all, I upped the boost from 0.6 bar to 1 bar and it ran for almost 3 years, not a hiccup.
4G63T in stock is a detuned version from Evo. You may think the 40hp lesser is not much but other than the block, almost everything else are different. Cams, injectors, intake manifold, turbo etc etc. In stock, you get about 180-190whp if your engine is healthy. 0-100 is around 8.5 secs just to be conservative. The spec-sheet claim of 6.5 secs is not possible. The INVECS II slow-box robbed huge hp from the engine. Additionally to make things worse, the car weighs over 1600kgs!
For ECU-remap and tuning, you can look for Ah Wah if you're living in Klang Valley (contact on pinned thread). He specializes in Evos and Airtreks. Congrats and enjoy your ride!
  • Like
Reactions: sweelt and vr2turbo
badguy
951
hi all sifu here,
about the ATF
booklet say Diaqueen ATF SP3
but in the market hard to find now
all selling normal ATF SP3 without diaqueen wording
and they say mitsubishi malaysia bought diaqueen in barrel and repack in malaysia in package without diaqueen wording
so is it true?
hi all sifu here,
about the ATF
so is it true?
Ha? Odd.. my spare parts shop has the Diaqueen stock. Maybe old stock. If you can find SPIII then that'll work for you. Diaqueen is just the brand. Get the fully syn SPIII la.
6UE5t
6,756
1,300
hi all sifu here,
about the ATF
so is it true?
Buy from Bintang Auto Parts, they have plenty of stock. I bought many parts for my Evo from them, guaranteed genuine.
Mitevo7
1,456
179
I also sourced my Lancer parts here, prices are reasonable and imported from Japan !
badguy
951
i from JB any recommended shop in JB?
I'm a 18 years old student, driving wira aeroback 1.3 ori engine (i think its ori, somtimes) with 1.5 interior 1.6 body (wtf?, its is true, no lies and i hate that alot) original grey.... I'm getting my car into whole metalic / pearl white with blue base, but i want to do some air brush on my bornet with mashimaro picture :biggrin: and some tribal on the side...any senior out there have good advise for me? :smile:
