anyone can help me find one set of toyota 3t wiseco piston??? 86mm bore size..... or any racing piston also can..... i had try others piston ...also cannot tahan ..... need help here...!!!! thx in advance.....
for 3T? i suggest you go for 1jz piston....i dont believe a normal turbocharged 3T can whack until a 1jz piston untill crack. n its much cheaper than the wiseco piston that u mentioned
does the piston pin suit the 3t conrod??? hehe....coz my 3t already n/a mod kau kau one.....juz the damn piston not tahan..... i whack my piston 3times lor....the ring also not tahan....hehe....
to save money,u can try what rexun mention above.using the supra piston.
u can try n source it n check out the pin first whether it's compatible with
ur con rod.if not,maybe a bit mod wont hurt.
the pin is not fit u need to bore abit of the 3T piston pin hole as the 3T's is larger... if your car is NA then i would suggest u not to use 1j piston as the compression is relatively low.. and u will complain lack of power... if urs is turbocharged by all means go for the 1jz piston... if u were to play NA i guess no other choices but either getting the aftermarket ones or use back those 3T ori piston
HAHA......yup is n/a ......juz really hard 2 find a high comp piston.... erm...wat aftermarket piston suits??? hehe.... coz i really boring 2 change piston n piston again...haha.....
he is playing NA le.... the pin location makes the 1jz/2jz piston seat lower hence lower compression ratio which is not suitable for his application
oh bro mind telling me how your piston got broke. cuz for an NA the reason of a piston broke doesnt boil down on the piston quality alone... there might be another consequences
haha....coz i using weber DCNF ....i also not sure why will whack the piston.... hehe.... my fren also ask me why....i juz say dunno wor.... coz my engine is 2t ..fit in 3t bottom end... the crank and the rod.... then i port n polish the head n change bigger valve.... and install a reprofile cam.... thats all lor..... dunno why sudenly i tarik then whack the piston..... number 4 piston kena...hehe.... i also feel very funny......
aes motorsports
bro... i wan go for high com piston...as renxun said.... 1jz or 2jz piston not suit for me lor....later many prob again.... hehe....juz thx for ur kind help... but if i got anythings that need i will contact u....so wheres ur shop locat at?? mind if u go chit chat wif u?? haha.....
wat size is the piston pin anywhere???? will call u when free...coz wan keng wif my dad again....wakaka...he is the boss....anywhere where is ur shop ???
Renault, a brand that was once known for its commercial vehicles like the Kangoo has been making significant strides in Malaysia. Over the past two years or so TC Euro, the distributor of everything Renault in Malaysia, has introduced a number of worthy cars like the Clio 1.6, Espace, Koleos, and the Laguna Coupe. But that's for ordinary people, leading ordinary lives and want...
