need help for TyT vellfire
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Its weird coz the abs and check engine light came on at the same time.
Did u drive through standing water at high speed or go through deep water?
If yes then could be just a wet sensor or connection.
Bad alternator and weak battery oso can contribute to warning light but most of the time it will be intermittent.
dont worry too much abt the abs light as u still have normal braking functioning as usual.
Is that ABS or traction control?
Long distance driving and suddenly the light turned on? Were you speeding a lot? Perhaps you have a overheated gearbox. Just stop for a 10-15 minutes let the car cooldown and try again
ken yeang
6,000 RPM
6,617
1,327
I think its traction control.
Anyway, the cheap effective way to prevent sensors from tercabut is use some zip-ties. Just have to make sure they are not exposed to hi heat.
enyone know where can find toyota map sensor ? 2jz-gte or 1jz-gte or other toyota turbo engine use:rolleyes:
