Myvi 1.5SE suspension ugrade
Jun 4, 2019
28
yeap..so comfortable my gf, my friends and family they all dont know that i've changed to adjustables when they r in the car. Only realize when they look at my car and find it lower than usual
hi cikit17, just curious by KYB adjustable, do you mean RS Pro? also when you mentioned comfortable, how comfortable it is when compared to stock?
cvkit17
2,884
1,354
Yes im using RS Pro. It has diff valve load so at low speed it is like only 30% stiffer than stock. But on high load u can feel that it is 50-70% stiffer than stock, especially going through pot holes and speed bumps. Hard cornering wise, 100% better than stock.
ixeo
4,788
3,080
KL, Malaysia
I'm actually curious about the Kayaba RS Ultra product, since I have no interest to lower a Myvi. Wonder how good is the Ultra.
6UE5t
6,000 RPM
6,756
1,300
I used before on my Livina, as mentioned by cvkit17, much better handling than stock. Unfortunately not widely available for many cars.
cvkit17
2,884
1,354
They market it as heavy duty absorber, no? Not sure if its for performance or for longetivity..
Jun 4, 2019
28
thanks for replying. it should be a good try compared to other coilovers. truth be told, if eibach & koni make parts for myvi, it would eliminate all the headaches. i do also wonder if this so called rear frame brace is good (not anti roll bar). i know that going for the anti roll bar for myvi is gonna hinder the suspension from absorbing bumps properly & cause unnecessary vibrations on irregular roads.
My 1st gen Myvi is on Kayaba RS Ultra now. It's significantly stiffer than stock by about 40% I'd say. Borderline bouncy but not quite there. Firm enough on corners but supple enough on normal roads. Worth noting I'm running stock everything including wheels. So for me with these absorbers the tyre pressure heavily dictates how bumpy my ride is. I'm running 230kpa tyre pressure so it's just enough bumpy in my opinion. I like it.
I am using this rear torsion beam bar - it does stiffen it up by about maybe 30% considering everything else on my car is stock. You can only realistically feel it in a corner, it just holds the body roll a bit better. I have another 2nd gen Myvi (pre-lagi best) that doesn't have the bar and the way it rolls is more sudden compared to with the bar.
The brace I dunno. I don't have that.
Errr any guy try STP injector cleaner before??? RM10 per bottle..
Planing buy 1 bottle to test lahh..any try before?? told u story mahh..
