mivec bumper!!!
anep
anep
110
subang airport
hello!
just want to ask one simple yet complicaterd for me,
the question is:
do i need to modify a lot just to change my satria bumper to mivec bumper!
i don't want to change the fender, headlight, all sort of thing i just want to change the bumper only.
what should i do to change the bumper, or it is just plug and play!
ambayah
ambayah
1,326
This bumper:
All can fit well, just the side put have to cut the section that touches from the bumper with the fender..
If you ask me, not worth it to cut. Looks & fells ugly.
anep
anep
110
subang airport
ambayah said:
This bumper:
yea that bumper,
u mean it must be cut a lot or just a bit?
which part is it the side one?
11000RPM
11000RPM
954
Johor Bahru
Hi there…
You need to cut both sides of the bumper. You’ll sacrifice both fitting holes for the bumper… I’ve done this before, trust me, not worth it…
I threw away the cut bumper and have to re buy the whole set again…
Anyway, just need both side fenders and signal lamps…
Pricing
Fender X 2 = Around RM160
Signals X 2 = Around RM60
J
anep
anep
110
subang airport
ambayah said:
Yo Tim,
That time I got my fender for RM60, bumper RM150 hehehehe
u mean if i change the fender and the signal it can be fitted into the original headlight and bonnet is it?
thanks alot for the info plus the diagram
ambayah
ambayah
1,326
YES BUT have to change signal also, so basicly you need the bumper, the fender, and the signals.
anep
anep
110
subang airport
last thing, if i got the bumper+fender+signal
so i don't need to modified a lot ler just plug and play!
is it?
MomoCorse
MomoCorse
83
Putrajaya
Hi.. just a little bit confius la... anep.. do you already make modification to ur car?i own a wira se. i want to change bumper+bonnet. if change the fender and signal, should i change the original headlamp also to fit the bonnet?
need a little help here because i'm short of budget to change the fender+signal+headlamp.
thanx.
zakie
zakie
131
:dancing2:
alo kawan i really need 2 find mivec bumper laaa
with the original lip & sport light....
my one sudah pecah laaaaa
do u guys can supply me one arr....
:dancing2:
masvidal
masvidal
253
Kota Kinabalu
hello there.
just want to know, if i want to use the mivec big spotlight bumper, can i use back the original proton grill? will it fit nicely? need any mod to the bumper?
GSR5559
GSR5559
1,314
www.zerotohundred.com
heres some info, shoot me if im wrong
mivec bumper and proton bumper is the same, wont affect headlites.
using mivec bumper with proton fender gota cut at the side part, if dun one to cut confirm gota change mivec fender and mivec signal lites, because mivec signals is short and proton signals is long. 2 different thing there. as for the headlites, no matter u change hood, bumper, fender or watever, it stills remain the same, still can use proton headlites. as for the hood side, if change to mivec hood, need to readjst the bracket (the one tht holds the hood) because proton hood, bracket is higher than mivec ones, dats why u can see mivec hood dun need grill where proton needs it to cover the middle hole.
masdival: for ur qestion yes u can use back ur grill if ur hood remain proton.
