Mitsubishi - 4G61 4G62 4G63 4G64 4G65 4G67 & 4G69
VinC
5
can any sifus pls tell me watz the series name for perdana SEi (2.0L inline four) engine?
qib_akip
286
KL & KUANTAN
steadyy bro... gud thing to share here... but wut bout me r, my body saga, but engine 4G63t.... can be apart of the family ke?? or shall name it mitsusaga?? hahaha...
p.e.a.c.e
n/a_tune
262
anyone know about mitsubishi diesel engine?? i find 4g68 block,, diesel engine,, but i dont know their cc (stroke and bore)
WiiR4
174
Bro can 4G63T evo 4++ use 4G62 1.8? planning to convert my satria neo to evo4 but since proton car can't go over 1.8cc. got my wira vr4 already use 4G67 block, so can i use the same method?
lowpro
109
15
would anyone know if the engine and transmission mounting points of the mitsubishi cordia and the wira are similar? thanks.
thrill_item
477
4
seremban/johor
Garrett Turbos:
Garrett basically has two lines of turbos. The ancient, inefficient T series turbos and the new, modern, ball bearing GT series turbos.
T family has T22, T25, T3, T350, To4B, To4E, TS04, To4R ...These are 50 year old, WWII generation turbos.
The newer line of GT turbos are ball bearing on journal and thrust bearing. The turbine and compressor wheels are improvely aerodynamically to flow more air. GT20, GT22, GT25, GT30, GT35, GT40, GT45, GT50... GT turbos produce slightly more hp then older T series turbos with the same number designation. A GT Garrett turbine wheel wil flow more air than similar sized Greddy turbine wheel. Thus GT turbos are able to boost higher and flow more.
Turbonetics and many domestic makers turbos based on T series turbos. A T3/To4E 60 T .63A/R is a hybrid turbo with T3 turbine, To4E compressor, 60 Trim compressor wheel and .63 A/R turbine housing.
Wheel "trim" refers to the squared ratio of the smaller diameter divided by the larger diameter times 100. Generally, the larger the trim number the more flow the wheel has.
For compressor wheels , larger trim tends to mean slightly lower efficiency.
For "families" of turbine wheels (those with the same inducer diameter), larger trim usually means better flow with less backpressure but longer spool time.
A/R is a ratio of the exhaust discharge area vs the distance from the center of turbine wheel to the center of the cross sectional area. Smaller A/R housing has faster spool up. Bigger A/R housing has less back pressure, more flow for the top end.
The so called "T-series': T60, T61, T66, T70, T72, T76... are T4 turbos as well. The number means the compressor inducer size. ie: T76 means it has 76mm compressor inducer.
HKS uses Garrett turbos. HKS GT series turbos use Garrett GT's turbine with GT's compressor.
For example, HKS GT 2835 is GT28 turbine with GT35 52 trim compressor.
The newer line of Garrett GT-R turbos are hybrid turbos. For example, GT30R is a hybrid of GT30 turbine mated to 56 trim GT37 compressor.
“Please be careful”. That was good enough advise for me and I made a dash for their baby as soon as I was handed the keys. We made way towards the east-coast highway and Bukit Tinggi and were joined by the R3’s lesser sibling, the standard Proton Satria Neo.
The first impression of the car is that it looks good, no credit to Proton...
